possible rotary uses?
Old Oct 14, 2002 | 11:47 PM
magazineracer's Avatar
has there ever been a motorcycle with a rotary engine? would it be a good idea?
Old Oct 15, 2002 | 12:44 AM
DonG35Miata's Avatar
There have been a bunch.
http://www.monito.com/wankel/motorcycles.html
Old Oct 15, 2002 | 01:35 AM
73JPS's Avatar
my ti
Try also www.rotaryrecycle.net
Old Oct 15, 2002 | 03:32 AM
Mazda man's Avatar
Endangered Species
When I couldnt get our lawnmower started I wondering if you could use a rotary engine in a lawnmower....but then I thought nah:D
Old Oct 15, 2002 | 08:18 AM
maikeru's Avatar
They also use them in aviation, which speaks to the wankel's reliability.
http://www.millville.org/Workshops_f.../aircraft.html
and
http://www.monito.com/wankel/aircraft.html
Old Oct 15, 2002 | 09:39 AM
There is also a tiny one used to power model airplanes!
Old Oct 15, 2002 | 10:46 AM
SmokingClutch's Avatar
Actually, there was a rotary powered lawnmower... monito.com probably has something on it...
Old Oct 15, 2002 | 05:15 PM
BlueAdept's Avatar
Moderator
One company made a rotary lawnmower as a fun spinoff to their rotary research in the 60/70's... I've seen a photo, but can't remember who. Might even have been Wankel himself.
Old Oct 15, 2002 | 06:52 PM
I loe rotaries, but I think a rotary lawnmower is pretty silly! It couldn't be cheap and there are good options in a two and four stroke. I think the rotary lawnmower is on the monito site.
Old Oct 15, 2002 | 07:02 PM
BlueAdept's Avatar
Moderator
Depends... could it be made quieter... I want to sleep on sunday morning, not listen to next doors lawn mower that sounds like he's got a tractor pulling competition going on.
Old Oct 15, 2002 | 11:51 PM
wakeech's Avatar
mostly harmless
actually, i think that the rotary (like a 100cc or something) would be perfect for a lawnmower, espeically as time goes on and emissions catches up with even the little 2 strokes... a rotary doesn't make that much less power/torque, and is far cleaner... it wouldn't really beat out a 4 stroke in that area, but it's really much better than the 2 stroke... NOT TO MENTION YOU DON"T HAVE GAS MIXING INTO YOUR OIL!! :D
Old Oct 16, 2002 | 09:11 AM
feelthesweetbea's Avatar
Arrow CHECK THIS OUT
Possible uses for rotary engine? you think youve seen the extreme? i would take one of these over an rx-8, even an 787B, anyday. ok im joking about the 787B, i would have to consider it strongly.
http://www.moller.com/skycar/technology/
The rotaries are not mazda, but there rotaries for heaven's sake....:D
Old Oct 16, 2002 | 09:48 AM
No pun intended... the Moller is never going to fly. Anyone who has flown even a small airplane will tell you it is a lot more intense and demanding than getting in a car and driving somewhere.
Old Oct 16, 2002 | 09:54 PM
N1XRR's Avatar
Rotary engines been in quite a few devices, many still in production today, but not what you think...
Motorcycles, cars and snomobiles have all had them. But the largest production, by volume, is pumps. Look around for rotary pumps. They are used for water, sewage, A/C, etc etc etc.
Michael
Old Oct 17, 2002 | 07:58 AM
red_base 95's Avatar
Aren't most helicopter engines rotaries? They need small, compact engines with little vibration that can turn very high RPM.
Could be totally off base.
Old Oct 17, 2002 | 08:25 AM
Yep, totally off base! Most helicopters are gas turbines... even smoother and higer-revving than Wankels. (Technically a Wankel is an orbital engine as the rotor does not make a perfectly circular path.) Gas turbines exhibit perfect rotary motion.
Old Oct 17, 2002 | 08:27 AM
N1XRR's Avatar
No, most helicopters are turbine-based....aka jet engine
Michael
Old Oct 17, 2002 | 03:26 PM
rototlewski's Avatar
the company that made the rotary lawnmower was the same that made the W-2000 roatary motorcycle, sachs/herculies.
here is a pic
Old Oct 17, 2002 | 03:32 PM
Mazda man's Avatar
Endangered Species
Rock on rotary! Rotary lawnmower, rotary model cars, rotary powered toothbrush....:D
Old Oct 17, 2002 | 05:26 PM
fuz's Avatar
fuz
non sequitr
Some university was working on a chemical battery that used a tiny rotary engine to burn a fuel source.
Old Oct 17, 2002 | 06:08 PM
wakeech's Avatar
mostly harmless
:p i dunno if i want a powered toothbrush powered with petrochemicals... just think of all that exhaust in the bathroom, the earsplitting noise....
but then again, super smooth operation, and power that would nearly tear your gums off!! count me in!!
Old Oct 17, 2002 | 07:11 PM
spud's Avatar
One of my dads air compressors has a rotary engine in it. It is a 6 horsepower model and is alot smaller than his other 5 horsepower compressor.
later james
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
garryg
Australia/New Zealand Forum
Oct 1, 2015 04:54 PM
JCTaylor
Sep 30, 2015 07:31 PM
