Which aftermarket suspension setup are you getting?
I'm thinking about ordering the Mazdaspeed schocks and springs set that lowers ride height by 20mm. What is everyone else getting? I wanted a more aggressive stance but I also wanted to retain pretty much the stock comfort level. Any other suggestions?
im waiting for JIC to come out with coilovers, they make really good stuff....especially for drifting
...but if they dont release anything....im gunna be going for tein as well the HE, and im also guna order the auto exe sway bars
andrew
...but if they dont release anything....im gunna be going for tein as well the HE, and im also guna order the auto exe sway bars andrew
Re: tiens
Originally posted by gr8rx
i plan on getting the tien type flex coilover suspension with edfc very adjustable and probably one of the best aftermarket suspension setups in my opinion
But maybe tein will actually put some fatter valving on the new flex's. EDFC was VERY cool though!
I'd wait for the JIC's at least the FLT2's. Much better quality... just not as easy to adjust the dampning
Re: Re: tiens
Originally posted by syntrix
Hopefully tein will use better valving. I had the flex with edfc on my wrx, and it was not that great at all. Sure it's gimmicky, but that's about all.
I'm going to stick with the stock springs and shocks (they are Tokico's :D ) and just throw on either a mazdaspeed or corksport sway bar set. It should reduce body roll greatly while not lowering the car any (a must for winter) and it should keep a fairly comfortable ride I suspect.
Re: Re: Re: tiens
Originally posted by Efini 8
tein doesnt re-valve their coilovers to match the conditions of America's roads. In japan their roads are super smooth so they have really STIFF ratings. JIC however does re-valve their coilovers to adjust to USA. Tein is made in China I may add...
The two tein boxes I have (for flex's, and an EDFC) are both labeled "Made in Japan"
EDIT: This could also mean that just the boxes were made in Japan, heh
hufflepuff
May 30, 2016 10:45 AM
duworm
Oct 1, 2015 04:57 PM
Learners_Permit
Sep 27, 2015 07:38 PM
