Rough cold start anyone?
Old Aug 21, 2003 | 01:19 PM
RX8-TX's Avatar
Senior Geek
I noticed a couple days ago, when starting the car early in the morning after it spends most of the night sleeping outside (waiting to get a damn car port at my apartments...) that there is a throaty note to the engine for a few seconds.
Is this common for a rotary engine?
I can turn it off & on and it wont do the same thing again.
BTW, I checked oil FULL, using SHELL 91oct gas, and barely 350 miles.
Old Aug 21, 2003 | 01:25 PM
wakeech's Avatar
mostly harmless
...you mean it stutters, or it simply makes a different sound starting up (and doesn't struggle to get going)??
Old Aug 21, 2003 | 01:29 PM
RX8-TX's Avatar
Senior Geek
Nope, doesn't seem to be stressing more than the usual. I know it takes a few more cranks to get it going than a regular piston engine.
The noise is simply unusual for what I am used to on this car. It doesn't seem to be normal high rpm for a cold start, it is as If for a second I was starting a V8 instead of a rotary.
Old Aug 21, 2003 | 02:28 PM
zerohour's Avatar
Ya i know what you mean. It happens right in the morning you turn it on and it sounds actually pretty agressive then once it warms gets into its idle and the fluids slush around everything is back to normal.
I actually love that sound lol! Like a mean growl...
Old Aug 21, 2003 | 02:33 PM
RX8-TX's Avatar
Senior Geek
May I presume it is normal for our 8s?
Old Aug 21, 2003 | 05:47 PM
eccles's Avatar
Prodigal Wankler
Re: Rough cold start anyone?
Originally posted by RX8-TX
I noticed a couple days ago, when starting the car early in the morning after it spends most of the night sleeping outside that there is a throaty note to the engine for a few seconds.
This was previously discussed in this thread
Old Aug 23, 2003 | 08:17 PM
91vert's Avatar
I have noticed it too. It is sort of like a few seconds of popping and light backfiring. My RX-7 always does that, so I assume it is something that rotaries just do.
Old Aug 23, 2003 | 10:08 PM
Lock & Load's Avatar
Smile
Just love that early morning GROWL when you start her up , for those of you with a dirty mind yes i am talking about the car.
ladnarf1
Apr 29, 2021 11:53 PM
Jaco Greyling
Jan 6, 2019 08:39 AM
IamFodi
Series II Interior, Audio, and Electronics
28
Oct 31, 2018 06:37 AM
Redheddude222
Aug 24, 2015 09:14 AM
dbarber
Jul 25, 2015 01:34 PM
