Alarm not flashing the indicators
Old Aug 18, 2003 | 11:45 AM
eccles's Avatar
Prodigal Wankler
My car has mysteriously stopped flashing its indicators when the alarm is armed and disarmed. The alarm still functions fine as an alarm, but without the visual confirmations.
Anyone else seen similar behaviour?
Old Aug 18, 2003 | 11:47 AM
brothervoodoo's Avatar
RainMan is Back
check fuses?
Old Aug 18, 2003 | 11:55 AM
eccles's Avatar
Prodigal Wankler
Originally posted by brothervoodoo
check fuses?
Not yet. Don't know what fuse it might be - the alarm is still functioning, as are the indicators and hazards - it's just the connection between the two that appears to have gone away. I'll have a rummage at lunchtime.
Old Aug 18, 2003 | 12:52 PM
dcfc3s's Avatar
RX-7 Guru
Do you have the shock sensor upgrade? Could be a flaky connection at the shock sensor.
Dale
Old Aug 18, 2003 | 03:01 PM
eccles's Avatar
Prodigal Wankler
Found the problem
User error: the trunk was ajar. I must've popped it open sometime over the weekend, and then forgoten about it. Since it doesn't swing open when it's unlatched, I've aparently been driving around with it ajar for the past couple of days.
Close the trunk and voila, the lights flash as they should. Kind of a neat feature, actually, though if it's mentioned in the manual I must've missed it.
Old Aug 18, 2003 | 03:58 PM
TreknMazda's Avatar
Love it! Keepin' it!
As I was reading through the thread I was getting ready to tell you the trunk may be open. Happened to me, too.:p I find that occasionally, I hit the trunk button instead of the unlock button.
Old Aug 18, 2003 | 04:11 PM
eccles's Avatar
Prodigal Wankler
Since the trunk doesn't fly open when it's unlatched, it'd be nice if there was some sort of indication on the dash that it was ajar. Perhaps the "door open" light could also indicate "trunk open". I know I'd be pissed if I lost something out of the trunk because I hit a bump and it flew open because it wasn't properly latched.
Old Aug 18, 2003 | 04:15 PM
Lensman's Avatar
_________________
I'm amazed at this: even my cheap 8 year old Rover has a warning light for the tailgate being open. Astonishing that Mazda missed this. They put a luminous sign and opening catch INSIDE the boot/trunk but no light on the dash. Doh!
Old Aug 18, 2003 | 04:29 PM
RainMan is Back
I'm just surprised that in a couple days you never hit any bumps! I running over speed bumps all day long, because of my driving conditions I would have noticed the the truck open. At least the issue is solved!
Old Aug 18, 2003 | 08:45 PM
8-it_please...'s Avatar
New to the forum. Question, does it flash when you lock the door using the door lock button on the door panel? It use to flash before I had the alarm upgrade. Does your flash with the upgrade? Thanks for the input.
Old Aug 18, 2003 | 09:22 PM
dcfc3s's Avatar
RX-7 Guru
Actually, I'm surprised they didn't include a Trunk Ajar light - the RX-7 had an idiot light when the hatch was open or not closed fully. Which, in a hatchback car, is kind of obvious to not even need an idiot light...
Dale
Old Aug 20, 2003 | 07:58 PM
myrx8's Avatar
Alarm horn
I surprised how loud the horn is when you press the alarm arm buttom twice. I bet you can here it in the next state!!!!
Old Aug 20, 2003 | 10:50 PM
B-Nez's Avatar
Re: Alarm horn
Heh heh, yeah try hitting while parked in the garage with the door closed!
RevMeHarder
Jun 1, 2026 02:30 PM
theblinkof
Oct 4, 2023 05:24 PM
Forevermore
Sep 20, 2015 01:04 PM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
