Interesting Idle Vacuum Correlations
Old May 22, 2006 | 07:41 PM
MazdaManiac's Avatar
Correlation #1:
Phoenix, Arizona is hot. Very hot.
When I came here, I was still using the recommended 5w-20 viscosity oil (Mobil 1).
That stuff would turn to water on a 105°F day, so I started thinking about the effects of a heavier oil.
After a few months of being in Phoenix, my idle vacuum stabilized at -52 kPa once the car was warm. Though this is on the low-side, it is still acceptable.
Last week I switched to 10w-30 Mobil 1. After that, my idle vacuum was stable at -56 kPa.
Conclusion - higher oil viscosity produced better sealing.
Correlation #2:
I just completed an 1100 mile round-trip to Buttonwillow CA and back. That is 1100 miles in two days, most of which was realized at 85 MPH and above. An interesting stretch of that trip was the section just north of Los Angeles where we climbed about 4500 feet in just a few miles. This was done in 6th gear and 90 MPH or greater. As you might deduce, I was in boost the entire climb which was several minutes - not something you would be able to replicate typically on the street. I was at 8+ PSI for up to 30 seconds at a time for parts.
This would, I think, qualify as EXTREME punishment. I wouldn't even do that to a car on the dyno.
Interesting observations/measurements -
Ambient temperature was 88°F at the foot of the climb and 72°F at the summit.
My coolant temps started at 202°F and finished at only 218°F.
My air intake temp was 100° at the base and 82° at the summit.
My A/F stayed at 11:1 for almost the entire run.
Net effect of all of this?
My idle vacuum is now about -58 kPa.
Conclusion? Punishing your motor is good for it.
Please feel to discuss.
Old May 22, 2006 | 07:50 PM
Nemesis8's Avatar
Bigus Rotus
Did your internals grow from heat and the clearances became tighter?
Old May 22, 2006 | 08:01 PM
mysql101's Avatar
hey, there are children on this board.
Old May 22, 2006 | 08:08 PM
Heh. My internals usually grow prior to heating. Hard to develop any real friction otherwise.
The effect has remained now after the motor has cooled completely, so I wouldn't think it is a short-term thermal result. There is simply something changed about the motor after "abusing" it that is positive in result.
It is worthwhile to mention that the idle is also smoother and the throttle response feels equally improved. Power is hard to judge since it is usually outrageous, anyway.
Fuel economy was good on the trip, but it often is when I just have highway miles. I normally see exactly 200 miles on a tank of "normal" driving and I saw over 300 on all four tanks on this purely "highway" trip.
Perhaps some sort of carbon deposit is now gone? Smoothing of the rotor chambers? Leveling of the seals? Improvement of the MOP? I don't know...
Old May 22, 2006 | 08:18 PM
mysql101's Avatar
The only way to get conclusive proof is to help turbo my car and run the test again.
Old May 22, 2006 | 08:26 PM
lshu's Avatar
Driving makes me :)
I've noticed that even quick runs to 9k will improve throttle response and power temporarily. I just speculated that it was the ECU adapting the fuel trim to the driving style. After a while, the engine "high" becomes normal again. Need.. another... hit...
Old May 22, 2006 | 08:37 PM
OK. Go ahead. I'll sit here at my PC and await your results.
Old May 22, 2006 | 08:38 PM
mysql101's Avatar
You must have missed the HELP part I'm only good at thrashing my car around the interstate like a madman with his *** on fire.
Anyway, I don't know if your conclusion is correct, but I want to beeeeeeelive.
Old May 22, 2006 | 08:40 PM
Yes, this has been noted elsewhere.
But that is not the point of this thread.
The above noted activities yielded a measured increase in idle vacuum. This is an empirical improvement in effective compression ratio.
Were not really talking about a direct performance change, just a difference in engine data.
Old May 22, 2006 | 08:45 PM
I can concur on a similar observation. Whenever I do a track day and drive the car at 9.5/10...it always runs much better when I go back to normal driving on the way home.
I have noticed the exaust tips are burnt of completely white as well...and the plugs are a purfect light tan color. After about 2 weeks of around town driving the car starts to idle poorly and stutter on pickup.
I'm going to check the Vac tomorrow..and then again after Wed and Thurs track days and see if there is an improvement
Old May 22, 2006 | 08:57 PM
this is a bit simplistic,
but thicker oil... better seal. better seal less blow by.... less blow by less heat.... less heat.... less ecu drops timing.. less ecu drops timing better gas mileage...
i have been doing premix for the last 4 tanks... reason, pm....
what have i noticed.... more power. mpg up 2mpg...
Old May 22, 2006 | 10:34 PM
Same oil for me.....no heating problems
I know the ECU isn't pulling timing from the logs
So there must be something to it
I do use premix at the track though.....HUMMMMMM
Old May 23, 2006 | 01:57 AM
my idle must be most excellent then ...
Old May 23, 2006 | 02:14 PM
30 seconds of 8+ PSI separated by 30 seconds of ~5 PSI over 5 or 6 minutes.
That is 6 minutes or so of nearly continuous boost.
Looking a the map, it may have been almost 10 miles of continuous climb on rt.5 along Lake Castaic.
Old May 23, 2006 | 02:21 PM
MadDog's Avatar
Consiglieri
I'll be interested to hear the vacuum readings after you change your oil the next time
Old May 23, 2006 | 02:45 PM
I don't think it will change much - I'm not going to anything heavier.
It is also interesting to note that I consumed no oil on the trip. The dipstick is reading exactly the same as he did when I left Phoenix on Saturday morning, though he's tired.
The oil level is the same as well.
Old May 23, 2006 | 02:49 PM
brillo's Avatar
Go Texas Longhorns!
I'm out of 5W-20 royal purple, I was planning on trying 5W-30, which I will do now just for fun and see what I think.
Old May 23, 2006 | 02:54 PM
5w-30 should produce the same result since the hot viscosity is the same.
Old May 23, 2006 | 03:22 PM
brillo's Avatar
Go Texas Longhorns!
Good point, I missed that you were using 10W-30
Old May 23, 2006 | 03:25 PM
I was at the Maz Fest and looked for Mazda Manic in the infield. Remember that dust cloud?
Anyhow, same results here better idle and running, then after a couple of weeks
same trashy pig rich conditions.
Old May 23, 2006 | 05:33 PM
i thought that the lower # was the cold viscosity and the higher # was the warm????
Old May 23, 2006 | 05:42 PM
Correct. I'm using 10w-30. He wants to use 5w-30. The warm viscosity is what we are talking about and those are the same.
Old May 23, 2006 | 05:51 PM
i was looking at the change fred was going to do from 5 20 to 5 30 which is what i did....
thanks mm
Old May 23, 2006 | 06:38 PM
I might even try 0w-40 Mobil 1 and see what happens.
This is the oil Porsche recommends.
Old May 23, 2006 | 06:41 PM
mm,
i am very suprised that you run mobil 1 ... do you get some sort of deal on it?
