Microtech Software and Serial to USB Adapter Issue
Old May 20, 2006 | 11:49 AM
brillo's Avatar
Go Texas Longhorns!
Wasn't sure where to post this one, I'm trying to connect my interceptor to my laptop via a usb to serial adapter, i set the adapter up, and set it to Com 1, but the software still can't seem to communicate to it. It trys to lock on for a moment and then throws a error code.
does it matter where the microtech serial laptop adapter is plugged into the chain of cables?
Any thoughts?
Old May 20, 2006 | 12:05 PM
It should be OK as long as it is between the adapter and the unit.
You might want to try and uninstall the driver and re-install it..or change to a different COM port. Your laptop may have conflicts on COM1
I have huge problems with mine when i run GPS with the Scanalyser.....different ports but the adapter software that drive the different serial-USB adapters can't co-exist at the same time. I usually have to remove one to get it to work
Old May 20, 2006 | 12:40 PM
brillo's Avatar
Go Texas Longhorns!
i'm not running any other serial devices on this laptop, i un installed any other usb devices and re installed the drivers. hopefully this will help.
Old May 20, 2006 | 01:28 PM
Nemesis8's Avatar
Bigus Rotus
I bet you need to pick COM5 if you can. Do you know how to change the COM ports setting for the USB adaptor? It can be done.
Old May 20, 2006 | 02:24 PM
brillo's Avatar
Go Texas Longhorns!
I do, but I'm not sure if the MT software can use COM5
Old May 21, 2006 | 12:12 PM
Did you get it working??
Old May 21, 2006 | 12:26 PM
brillo's Avatar
Go Texas Longhorns!
yup, a simple switch of converters worked, thanks for the help guys
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
WranglerFan
Nov 5, 2017 09:35 AM
tgaffner
Sep 7, 2015 08:49 PM
