clear side markers
Old May 14, 2006 | 04:17 PM
hobby's Avatar
clear side markers
How do you get those little plastic screws to come out without damaging them? Mine won't budge.
Old May 14, 2006 | 04:20 PM
In the fender wells?? They turn about 1/2 turn and then pull out the center section.
If they are full of dirt they are difficult to get out. WD-40 or even water may help.
If you break them they are about a buck each to buy new ones
Old May 15, 2006 | 09:12 PM
poorman's Avatar
The screw is in two parts, a center and an outer.
If it gets dirty like the above has stated, you can use wd-40 or do what i did.
Hold the outer side of the screw and turn the inside with the screwdriver. Usually this would cause the center to twist and pop out a little like it should. Make sure your only holding the outer side of the screw.
If this does not work used the wd-40
Old May 15, 2006 | 09:47 PM
NgoRX8's Avatar
get a philips screw driver and turn slightly to the left. you will see it come out. if it's stuck for some reason you'll have to loosen it by popping it out a lil while you turn.
WranglerFan
May 31, 2022 07:51 AM
WranglerFan
Nov 5, 2017 09:35 AM
mitchrx8
Sep 13, 2015 08:05 AM
blkswan
Sep 2, 2015 10:04 PM
