Broken Lug Adapter!! Buy Spares Early!!
Old Apr 21, 2006 | 02:53 PM
willhave8's Avatar
Do you have a Silver 8?
Lots of bad stuff seems to happen to you. Deer, bad cat converter, other things I forget but remember you writing about, now broken lug nut key and the resulting fiasco...
Old Apr 21, 2006 | 02:58 PM
or don't buy cheap parts in the first place
Old Apr 21, 2006 | 03:02 PM
They should have had no problem getting them off....sometimes I wonder ........
You could have gotten on of the 14 YO kids from the neighborhood to take them off.....I'd bet they'd be done in 10 min or less...and no scratches on the rims
Old Apr 21, 2006 | 04:15 PM
itsallaboutgary's Avatar
ohh man...i remember myself trying to take off one of the OEM wheel locks off of my car, it was so tight that i forced too much pressure on the lug nut and the key practically stripped all around. it sucked so bad, but then i took my car over to a tire shop and they took a hammer and pushed the key as far into the lugnut as possible, and that did it. no more wheel locks for me, atleast for the stock 18s. =) that is what happens when you are careless, so people out there, becareful! oh yeah. always purchase two key adapters.
Old Apr 21, 2006 | 05:51 PM
RedSheDevil's Avatar
.:. causing mischief
One of my OEM wheel locks (AND KEY) stripped last fall when I was swapping out the winter tires. Thank God for this site, which had a great step by step way to bang a socket onto the stripped lug and force it off. I removed all the locking lugs when I put the stocks back on this spring, then found out about a rash of punks stealing the OEM wheels.
Sadly, a lot of these punks are too lame to get the wheels off before someone sees them. This means you are driving away on either loosened lugs or (in one case) no lugs. Extremely dangerous!!
I am boycotting the crappy stock wheel locks (metal should NOT bend under the pressure of someone as small as I am) BUT I am looking into buying another set so I can keep my wheels on my car!
Old May 11, 2006 | 01:17 PM
BlueEyes's Avatar
Shitty deal. Why don't you just use standard hex lugs?
As far as wheel locks are concerned, I have in my possesion a universal wheel lock tool which will remove wheel locks. Theifs have this tool as well. The only wheel locks it hasn't worked on were on my buddies Porsche. I took a hole saw slightly larger than the wheel stud and drilled the lock off. If someone wants your wheels, wheel locks aren't going to stop them, but, they are going to make it a PITA for you to take your wheels off.
Old May 12, 2006 | 03:11 AM
brattesani's Avatar
broken swaybar king
my oz rims i use for autoX came with new lugs, i just use those on the stockers. i hate wheel locks.
Old Dec 8, 2006 | 12:15 PM
firebirdude's Avatar
User and Abuser
Originally Posted by Cool-Blue-Dad
They say, "hey, we found your lug key in your trunk - it's broken, we can't get the wheels off so we can't do anything." I slowly count to 10 remembering how clearly I explained that problem to them at 7:30am.
I can't tell you how many times I've been in this situation...... SOOOOO angry....
Thanks for the tip. I'm actually running on borrowed time right now. Vehicle was sold to me without a key at all.
On a side note, my father tells me that he has a universal key at his shop. You hammer it into place over top of the lock, then proceed as normal. I laughed too, but he says it's an actual tool. A universal key.....hmmm..
Old Dec 8, 2006 | 02:53 PM
LionZoo's Avatar
road warrior
I think I lost the key to my wheellock. It just gives me another reason to go to standard lugs. I figure if they really want my wheels, they can have them. Just gives me another reason to upgrade to aftermarket wheels.
gwailo
May 14, 2024 06:57 AM
Nisaja
Series II Interior, Audio, and Electronics
Nov 3, 2015 05:30 PM
Kahl
Aug 20, 2015 11:49 PM
