View Poll Results: Orientation of your red/blue dots & amount of counterweights:
Red/blue dots are at the valve stems - a lot of counterweights
80.00%
Red/blue dots are at the valve stems - little or no counterweights
20.00%
Red/blue dots are opposite the valve stems - a lot of counterweights
0%
Red/blue dots are opposite the valve stems - little or no counterweights
0%
Voters: 5. You may not vote on this poll
Tire Balancing
Old Aug 12, 2003 | 09:12 PM
Racer X-8's Avatar
Coming thru in waves...
Tire Balancing
A friend at work informed me that my tires were installed wrong, and because of that, I had a whole lot of counterweights added to my rims to account for it.
He said that, on the sidewalls of the tires, the red dots on the right and the blue dots on the left should be oriented opposite the valve stems.
I think he said that the dots mark the heavy point of the tire. To minimize required counterweights, the heavy side of the tire should be opposite the valve stem because the valve stem creates the heavy side of the wheel. So, the two heavy sides should be opposite each other to minimize the out-of-balance condition that is then corrected by adding counterweights. Any unneccessary counterweights make the whole assembly heavier, more polar moment of inertia to have to spin, reducing power output efficiency a little.
My red/blue dots are oriented at the valve stems & my counterweights look to be a lot, like about 4" in length.
I wonder if the pressure sensors have anything to do with this?
Old Aug 12, 2003 | 09:58 PM
highspeed8's Avatar
My tire's colored dots are at valve stems, and LOTS of counter weights, about 15 each wheel...
Old Aug 12, 2003 | 11:37 PM
eccles's Avatar
Prodigal Wankler
Re: Tire Balancing
Your friend is blowing smoke. This page, this page and this page all concur that the red (or yellow, if present) dots should be aligned with the valve stem (unless the wheel is specifically marked to indicate the heavy point of the rim).
On most modern alloy wheels, the imbalance of the bare wheel is pretty negligible, but the extra weight of the TPMS sensors on the RX-8 wheels means that the valve stem is always going to be the heaviest point of the wheel. The reason we have so many weights opposite the valve is to offset the extra weight of the sensor.
If the red dot wasn't aligned with the stem, then the tire's inherent imbalance (however small) would be working against getting the whole assembly in balance, and we'd need even more weights.
Old Aug 13, 2003 | 12:17 AM
Racer X-8's Avatar
Right you are! Good info. Looks like I have a tire mounting course to give my buddy tomorrow (today! I better go to bed!!! )
Thanks!!!
Hunterkelley24
Jun 14, 2022 08:32 AM
New_Mazda_Guy
NW RX-8 Forum
Sep 19, 2019 11:20 AM
Rx8 VA Guy
Jun 4, 2016 12:42 AM
Michael Bryant
Oct 12, 2015 03:07 PM
duworm
Oct 1, 2015 04:57 PM
