MAF Location
Old Apr 7, 2006 | 09:43 PM
Broker73's Avatar
MAF Location
haven't really paid too much attention to location, and I am sure I could pop the hood and look, but being lazy tonight
Heard chatter about cleaning MAF when you have drop in K&N? So where do I look
Old Apr 7, 2006 | 10:33 PM
Brice-RX8's Avatar
It is the little flat top rectangle on the intake tube going from the air filter box to the throttle body.
Old Apr 12, 2006 | 03:25 PM
ezrider55's Avatar
Two silver looking wiers in it are MAF.
Old Apr 12, 2006 | 08:15 PM
StealthTL's Avatar
Arrow Wires....
Disconnect the wiring, two screws to take it out, and pull straight up.
The brown doo-hickey you see on the end of the wires is a thermistor, measures the incoming temp. The actual MAF heated wires are up inside the housing, tough to see. Only a small proportion of the air goes up and over, past the sensor - this is the part that will spoil your day if there is ANY oil on it.
Spray brake cleaner or solvent up there, do NOT try and wipe it, even a q-tip will bend/stretch/break it.
S
nferguson88
Oct 6, 2015 12:45 PM
Sato Tatsuya
Oct 5, 2015 03:09 PM
alming1132
Sep 30, 2015 11:30 AM
tommy26Germany
Sep 29, 2015 10:33 AM
