fisrt 1/4 oil
Old Aug 11, 2003 | 10:35 AM
shaft's Avatar
fisrt 1/4 oil
who as put oil yet in is 8? i did alraidy at 800 km i had to put about a 1/4 liter the light come on after 800 km .i think that the sensor is very sensitive to had oil ,maybe because of bad experience.what do you think?:D
Old Aug 11, 2003 | 10:45 AM
Pete's Avatar
I didn't put any oil yet. I checked it this morning and I was still ok.
I have 1000KM on my 8.
I've fill up the car 3 times already. Not including the full tank when i picked up the car.
Old Aug 11, 2003 | 12:32 PM
mac's Avatar
mac
so close, I can feel it
Hey Shaft, check out the oil light threads in the main discussion section. Some are reporting that the oil light goes on even tho' no oil is required. It has something to do with the baffles in the oil pan. They need to be replaced.
Old Aug 11, 2003 | 12:41 PM
SirLeNerd's Avatar
Keeper of the Flask
I just added a litre of oil this past weekend. My oil light went on (only at higher speeds 120Km/h +). Checked the levels. I was down to 1/4. After adding the oil the light does not come back on. My dealer said that I should probably add oil at about 4000Km but I only had about 2100Km
Old Aug 11, 2003 | 02:48 PM
shaft's Avatar
sirLenerd:that what happen to me at hight speed the light come on have to put a 1/4 and it never appear again .but this is suppose to be normal welcome in the rotory world:D
Old Aug 11, 2003 | 06:55 PM
Deep Blue's Avatar
with a Red 8
Not just the rotary world...my BMW 330Ci used to suck down oil like it was going out of style.
I used to have to put 2 quarts in every 5,000km or so....meaning 1/4 off of the stick after 2100kms isn't anything to worry about. These engines just run hot as hell, and burn up the oil.
Old Aug 11, 2003 | 10:40 PM
MadJoker's Avatar
Do you have to check oil when engine is hot or cold, it says in the manual to check it at normal engine temperature, like 5 minutes after shuting down engine so oil goes back in pan. So I check it when engine was hot , and I had oil a bit over the top line, ( to much? I mean dealer preped the car )
I'm at 700 km
Madjoker
Old Aug 13, 2003 | 08:52 PM
Doctorr's Avatar
Ricer is Nicer.....
Cool Oil addage....
Still havn't added any oil, level seems static at 2/3 on dipstick....
Having trouble finding '5W20'.....
Local Crappy Tire told me it was a Ford special oil, and Autozone stocks it.....
Only made by Quakky State, 5W20 is $3.49 per(!) bought me a case.......
doc
Old Aug 17, 2003 | 08:23 PM
Wing's Avatar
Doctor, I found some at Walmart! Pennzoil $3.89 a quart I believe, so not cheaper, but easy to find at wally world. I picked up 2 "just in case" bottles.
I'm at 1050Km not needed yet, but it was overfull before, it's just at full now.
Old Aug 18, 2003 | 12:02 AM
MadJoker's Avatar
I'M at 1300 km and aded about half a pint. look around did not find any ( dealer fill it up ) will go check Walmart..
Old Aug 19, 2003 | 01:51 AM
canzoomer's Avatar
Forum Vendor
Doctorr
doc
Hey Doc, want to go halfers on a case with me if we find some at a decent price?
Also, call/email me to chat if you like. I am in Edmonton too.
maurice@harddata.com
Old Aug 31, 2003 | 02:35 PM
mmjames's Avatar
Question FIrst oil Issue
My oil light just came on at 690 miles, then went out again. I'll have to see what's up, after work.
Old Aug 31, 2003 | 02:48 PM
Wing's Avatar
I'm at 2100Km still full!
Old Aug 31, 2003 | 03:24 PM
rotorian's Avatar
I've put a full quart in at about 2500 km. Oil light was coming on intermittently.
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
WranglerFan
Nov 5, 2017 09:35 AM
