Has anyone noticed the cap on the muffler?
Old Aug 10, 2003 | 05:41 PM
kmead's Avatar
If you look up behind the rear valance, directly behind the black rotary emblem, you will see a round welded cap on the muffler. It seems like they were intending to offer a center exhaust and due to noise regulations capped it to make a two outlet muffler.
I suspect that we will see some modded exhausts with either 3 outlets or a single center in the near future.
Thoughts?
Old Aug 10, 2003 | 06:14 PM
compaddict's Avatar
I think someone should get a drill out and start experimenting!
[Insert sarcastic icon]
Vince
Old Aug 10, 2003 | 06:19 PM
eccles's Avatar
Prodigal Wankler
Yeah, the Parts & Service Manager at Mazda South and I took a good look at that while mine was on the hoist for its PDI. He was thinking along the lines of an electronic dump valve and a pipe out through the center of the rotary symbol in the middle of the lower bumper valance. However, I suspect that you'd run into problems with the plastic bumper melting due to the close proximity of that hot pipe; note that the factory dual tailpipes have plenty of clearance around them to prevent that happening.
That said, I would not be at all surprised if someone was to come out with a kit for it.
Old Aug 10, 2003 | 06:58 PM
kmead's Avatar
Well given the internal construction of the muffler, as seen in the cutaway, I can see why the cap and why no one will want to take it off... Straight pipe out the back.
Maybe a Y pipe to two mufflers and then back out to the center with another Y to create the outlet.
My Vince you are a sharp one.
theblinkof
Oct 4, 2023 05:24 PM
Michael Bryant
Oct 12, 2015 03:07 PM
duworm
Oct 1, 2015 04:57 PM
Racingjunkie
Sep 29, 2015 05:05 PM
