Changing the fog lights and running lights
Old Aug 9, 2003 | 05:52 PM
BRx8's Avatar
Ero-sennin
I'd like all my lights to be a bright white light just like the HID headlights. Has anyone attempted to change the running light bulbs and the fog light bulbs? I was wondering what types of bulbs they are for both.
Old Aug 10, 2003 | 01:26 AM
mikeb's Avatar
100% Italian
the light closest to the mazda badge in front use the small wedge bulbs the same bulb that lights up your back license plate. I change mine it white to match the hid. Also the foglights are H11 bulbs
Old Aug 10, 2003 | 11:03 AM
BRx8's Avatar
Ero-sennin
how were you able to change them? i looked in there and it looks really tight...did you have to remove the front wheel well covers like it says in the manual?
i also checked the fog lights and my front air dam blocks the front while the radiator blocks the back...i don't think they can be replaced easily
Old Aug 11, 2003 | 01:23 AM
mikeb's Avatar
100% Italian
ok the lights in the front closest to the mazda badge are hard to remove but can be done I already changed mine. Don't touch the wheel well, pop the hood and take the battery cover and ecu cover off and then you can get those bulbs out. The foglights are not to hard either. The foglight on the passenger side you can just use your hand to disconnect it. However the foglight on the driver side is harder and I haven't taken it out yet because I'm waiting to get the H11 bulbs to replace the stock foglights first.
Old Aug 12, 2003 | 04:11 PM
mikeb's Avatar
100% Italian
the foglights use a H11 bulb which I found out is not avaiable yet and won't be for a while
Old Aug 12, 2003 | 10:32 PM
mikeb's Avatar
100% Italian
its hard to see but this is a pic of the small inner light next to the mazda badge I replaced with hyper white instead of orange or stock cream. HID is off for pic
Old Aug 12, 2003 | 10:33 PM
mikeb's Avatar
100% Italian
here is a pic of back light I changed to hyper white
Old Aug 13, 2003 | 01:39 PM
BRx8's Avatar
Ero-sennin
it may just be the picture, but it still looks a little yellow to me...how does the "whiteness" compare to the HIDs?
also, will these work for the foglights?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2426808008
Old Aug 13, 2003 | 02:56 PM
mikeb's Avatar
100% Italian
The light looks really good next to the hid, I know the picture suxs but it looks so much better in person. As far as the foglights that ebay item is exactly what we need for the foglights. I'm glad you showed me that
Old Aug 13, 2003 | 03:06 PM
BRx8's Avatar
Ero-sennin
well you can probably find them cheaper elsewhere, i just did a real quick search for "H11" and that's the first thing i found...
plus these are used for headlights...you mean to say that our foglights require headlight bulbs?
PS - i'm planning on changing the clear corner lights as well...i think i want all the lights (except high beams) to be white...
EDIT: here are some eBay links for the lights:
Clear corners (194)
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2427162934
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2427221106
Fog Lights (H11)
http://cgi.ebay.com/ebaymotors/ws/eB...category=33710
I don't know the bulb size of the ones closest to the Mazda badge...
Old Aug 13, 2003 | 03:21 PM
mikeb's Avatar
100% Italian
yes, h11 can be used for headlights but for our car they are used as foglights. I had H3 bulbs for my civic foglights and headlights
Old Aug 13, 2003 | 04:29 PM
CraziFuzzy's Avatar
You are sleeepppyyyy.....
racinglab.com also sells some H11 White bulbs
Old Aug 13, 2003 | 05:54 PM
mikeb's Avatar
100% Italian
thanks I'll check that out
Old Aug 16, 2003 | 10:42 PM
mikeb's Avatar
100% Italian
I changed all the lights to hyper white..It's hard to tell but heres a pic
Old Aug 18, 2003 | 04:08 PM
onix527's Avatar
nice lights could you post where you brought them and how much? also whats the # for the running lights closest to the mazda badge, Also has anyone changed the interior dome lights? if so what type of bulbs does it require.
Old Aug 18, 2003 | 05:47 PM
mikeb's Avatar
100% Italian
the foglights are h11bulbs $20 bucks
The lights near mazda badge are same as light that lights back license plate and same as lights in passenger and driver door. I also changed dome light. Dome light cover can be popped over with flathead. Dome light was $8 bucks
Old Aug 19, 2003 | 08:54 PM
TerenceT's Avatar
H11 for 25 bucks
http://www.supremepower.com/category.../spplight.html
per audiworld.com's thread, this is actually a group buy, i am going to get some yellow for my fog lights
Old Aug 20, 2003 | 10:38 AM
BRx8's Avatar
Ero-sennin
I got my H11's for $34.95 and have a color temperature of 5,800...they are Xenon and Krypton gas filled...i have yet to bring it into the shop to have them done, perhaps later on today
Old Aug 20, 2003 | 10:50 AM
tripwire's Avatar
W!ck3d $!ck
ok, what are the bulb numbers for that little round light nearest the Mazda Emblem?
I understand that the fog lights are H11.
Old Aug 20, 2003 | 11:29 AM
BRx8's Avatar
Ero-sennin
those are 194's, same as the corner lights...these are the ones i got (i got 2 pairs, a pair for those parking lights and a pair for my clear corner lights):
Old Aug 21, 2003 | 03:46 PM
mikeb's Avatar
100% Italian
brx8--- your pm is full so I'm telling you the guy that did my car took five minutes and on the passengerside foglight he used his hand and on the driverside he got on his back undid about four screws from bottom plate and put his hand straight up and changed the foglight. sorry you are having a hard time
Old Aug 21, 2003 | 04:27 PM
Bengal Tiger's Avatar
I'm confused...could someone point out the parking lights, and the dome lights....i haven't been sleepin much, and I'm too tired to search...help! please. thank u.
Old Aug 21, 2003 | 04:56 PM
mikeb's Avatar
100% Italian
dome light is inside car and parking lights are the foglights, corners by your rims and inner small light by your mazda badge in front of car
Old Aug 21, 2003 | 08:43 PM
BRx8's Avatar
Ero-sennin
FINALLY! got those suckers in...ok, this is what needs to be done...you have to unscrew 3 screws from under the car...they keep that plastic guard in place...1 is a plastic screw and the other 2 are metal...you don't need to take the entire thing off, just enough to get your hand in there...i suggest you wait until the car is cool as you may brush up against some really hot pipes back there...
then you can basically reach straight up, undo the connector and twist the H11 out...it's REAL easy once you know what to do, which is go from under the car...i tried vehemently going from the side of the foglight to the top but it's damn near impossibly as you'd have to have really small hands and wrists
i'm still waiting for my 194's to change the parking lights and the corner lights but i can already tell it looks A LOT better when all the lights are bright white...well, except if you have a yellow car then amber is feasible but not on a black car
will post pics once i change the other bulbs...thanks mikeb for all your help...much appreciated
Old Aug 22, 2003 | 01:29 AM
mikeb's Avatar
100% Italian
glad you got them-- post the pics when done
