ebay stainless steel clutch line
Old Mar 12, 2006 | 04:34 PM
woodysjh's Avatar
I already searched!!!!!!!
Has anybody bought this from ebay?
Is it worth it? Is the quality good?
Stainless Steel Clutch Line
Old Mar 12, 2006 | 04:39 PM
RotaryManiac's Avatar
1st time rotorhead
How easy is it to install a clutch line?
Old Mar 12, 2006 | 05:20 PM
QBallz's Avatar
A 2001-2003 RX8 clutch cable?
Old Mar 12, 2006 | 05:21 PM
Rx-A-Ho's Avatar
Note the quote taken from the link:
"YOU'RE BIDDING ON
You are bidding on one 2001-2003 MAZDA RX8 Stainless Steel Clutch Line (Free clear coating)"
The first year of the RX-8 was 2004! Buyer beware.
Old Mar 12, 2006 | 06:00 PM
woodysjh's Avatar
DIY for clutch line
Old Mar 12, 2006 | 06:14 PM
ddub's Avatar
always preoccupied.
Corksport (www.corksport.com) sells a SS clutch line for 25 + shipping with free clear coating, $2 extra for color coating
Old Mar 13, 2006 | 08:13 PM
woodysjh's Avatar
Thanks guys,
Next question:
Do I have to, or should I, replace the brake lines with braided steel as well as the clutch line in order to get good preasure from the hydralics system in the car? Just wondering because aren't the clutch and brakes on the same system?
Old Mar 14, 2006 | 01:44 PM
QBallz's Avatar
^ They use the same reservoir, but not the same cylinders. You should be fine swapping out either Clutch or Brake lines.
You just don't want to swap, say the front brake lines and not the back. If you do the brakes do all 4 lines at the same time.
Old Mar 14, 2006 | 06:49 PM
woodysjh's Avatar
Thanks guys, I think I will replace the clutch line from the corksport site and see how well it improves the shifting before I do the brakes.
Old Mar 15, 2006 | 05:34 AM
unless you installed a heavy pressure plate there's likely no benefit, won't hurt either ...
Old Mar 18, 2006 | 06:42 PM
max5roadster's Avatar
INDY RX8 CLUB - Officer
I noticed substantial improvement in clutch feel and reduced "notchiness" over stock when I used the Mazdatrix SS line. Best cheap mod IMHO.
GARCIAC951
Sep 10, 2015 07:17 PM
ed0128
Sep 9, 2015 04:50 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
Rupanrx
Sep 4, 2015 06:44 AM
superROB23
Sep 4, 2015 01:22 AM
