Upgrade your swaybar bushings
Old Mar 3, 2006 | 10:52 AM
ULLLOSE's Avatar
05-08 SCCA BS Natl Champ
It took a few months and a very slow boat from down under, but now we can upgrade to poly swaybar bushings and use our stock hardware:
http://www.dpeweb.com/ProductDetails...9&vehicleID=58
p.s. these should fit the stock and MazdaSpeed bar.
Old Mar 3, 2006 | 12:43 PM
GeorgeH's Avatar
Thnkx, just ordered a set.
Old Mar 3, 2006 | 01:15 PM
cgrx's Avatar
DRIVEN
very nice upgrade
Old Mar 3, 2006 | 03:33 PM
they've been available since before the RX-8 came out, you can order Energy Suspension bushings from almost anywhere for a lot less and they have the grease fittings with new brackets even
Old Mar 3, 2006 | 03:36 PM
cgrx's Avatar
DRIVEN
didn't think they carried them
Old Mar 3, 2006 | 03:45 PM
http://www.jegs.com/webapp/wcs/store...0059&langId=-1
universal 1-1/16" Part no. 355-9-5162G for black color bushings, replace the "G" with "R" for red, $13.95 for a pair from Jegs linked above
When you go to install them the bracket on the top side will slightly overlay onto a clip that holds the ABS wire, bracket holes are slotted - push them downward as far as you can, when you tighten the nuts down the bracket will pull down and conform properly with a slight overlay on the clip, nothing to be concerned with
Old Mar 4, 2006 | 12:03 AM
ULLLOSE's Avatar
I have a set of the ES ones, did not like the way they fit with the MS bar.
Old Mar 4, 2006 | 05:23 AM
I don't have a clue why, they're more than adequate
Hunterkelley24
Jun 14, 2022 08:32 AM
Quiggs321
Sep 30, 2015 05:34 PM
drlubell
Sep 26, 2015 11:58 PM
