Loss of power ?
Old Feb 24, 2006 | 03:16 PM
Rich Rx-8's Avatar
Question Loss of power ?
I noticed that when i floor my pedal from stop the car pulls fine all the way up, but at exactly, and between, 6K rpms and 6.5K rpms my car lets off a little, then the torque seems to kick back in at 6.5K and higher is this normal?
Old Feb 24, 2006 | 04:46 PM
onekwik7's Avatar
I would'nt know because I never feel any torque, but it always revs smoothly.
Old Feb 24, 2006 | 04:48 PM
Rich Rx-8's Avatar
hmmm must be normal
Old Feb 24, 2006 | 04:59 PM
onekwik7's Avatar
You might be feeling the different intake ports opening but i am not sure. I think the intake tracts become shorter at 6275 rpm's
Old Feb 24, 2006 | 05:04 PM
StealthTL's Avatar
Post Flash me....
Sounds like you don't have the latest "flash" for the computer, it evens it out a lot.
S
Old Feb 24, 2006 | 05:06 PM
Rich Rx-8's Avatar
Maybe thats it I don't know if I got that flash
Old Feb 24, 2006 | 05:07 PM
ezrider55's Avatar
What StealthTL said. When was the last time you had your 8 in for service?
Old Feb 24, 2006 | 07:17 PM
Rich Rx-8's Avatar
two weeks ago
Old Feb 24, 2006 | 08:02 PM
olddragger's Avatar
should also have a "little hesitation" at 7300k. if you feel that at 6k or 7.3k and you DONT feel a tad bit more power right afterward--check your plugs and coils\
olddragger
Old Feb 24, 2006 | 08:10 PM
yiksing's Avatar
the giant tastetickles
Its normal, there's a bit of power dip somewhere around that rpm, lean mixture maybe. Just make sure its not totally power loss at that rpm and above, otherwise it could be a dead cat.
Old Feb 24, 2006 | 09:06 PM
Rich Rx-8's Avatar
def no total power loss just hesitation or seems to level out at 6K then climbs harder at 6.5K and up
Old Feb 24, 2006 | 09:08 PM
Rich Rx-8's Avatar
by the way I heard some people say that it's not safe to do high shifts out of 1st gear, what rpm would be considered to high to shift out of and can you cruise in first gear at high rpms?
Old Feb 24, 2006 | 10:50 PM
yiksing's Avatar
Yes you can drive in high rpms in 1st gear but not advisable since the engine is working hard but little air flow to the cooler and radiator. Secondly there's no point besides creating lots of noise and heat in the tranny as well. And yes its ok to shift out of 1st in high rpm but to shift into 2nd gear requires a lot of practice, I had the car for almost 6 months but I still can't manage a fast and smooth 1st 2nd shift.
tommy26Germany
Sep 29, 2015 10:33 AM
Trekk
12
Sep 25, 2015 03:08 PM
Emmanyei
Sep 19, 2015 11:12 AM
gnat42
Sep 16, 2015 08:47 PM
tgaffner
Sep 7, 2015 08:49 PM
