Airbox Help
Old Feb 13, 2006 | 08:01 PM
Slims8's Avatar
Piston Traitor
Airbox Help
In the process of removing my airbox, I broke a plastic nipple. Can anyone identify this piece and exactly what it's purpose is?
Old Feb 13, 2006 | 08:03 PM
It's a vacuum acumulator for the VFAD valve....You don't need it if you are removing the VFAD and installing an aftermarked intake so you are OK
Old Feb 13, 2006 | 08:49 PM
Slims8's Avatar
Piston Traitor
Actually I'm just modifying mine, but I guess I'll be ok. I just didn't want to buy a $150 part or something just to avoid the CEL.
Old Feb 13, 2006 | 09:09 PM
StealthTL's Avatar
Accumulator.....
Yep, that's the accumulator. If you are removing it, plug off the vacuum source under the throttle body, but leave the electrical connector hooked up to the solenoid (sounds complex, but pretty obvious if you look at the system) the computer MAY monitor whether the coil is working or not, avoid a possible CEL.
S
Old Feb 14, 2006 | 01:38 AM
KJ238's Avatar
Air + Fuel + Spark = Boom
What's the VFAD used for?
Shud this still be on if i have a aftermarket air-filter? I have a round thingy still connected... Should i remove it
WranglerFan
Nov 5, 2017 09:35 AM
Evan Gray
Nov 24, 2015 01:00 AM
Danield97
Sep 30, 2015 05:59 PM
protocol
May 15, 2007 12:34 AM
powerman
Aug 23, 2005 10:07 PM
