Chick speak please
Old Jan 11, 2006 | 09:23 AM
SpoiledBlk8's Avatar
Chick speak please
Yes I did use the search...... but I still don't get it
I am looking for wheels for autocrossing and to be honest I don't understand any of the "offset, backspace, ET, TPMS compatibility" lingo that goes with finding a wheel that will work. I called both of the Mazda dealers here in my area and neither one of them knew any more then the fact that I need an 18X8. So I called Mazda USA and learned that I need a 50mm offset. I found some Enkei's that are 18X8, 5X114.3, ET 42 and +42 offset, not TPMS compatible but they have TPMS for these wheels for an additional $400.00. Then the tech stated "I don't need TPMS just to autocross so just take em off", followed by "yep these wheels will work"
My question is, will these work without any additional modification? What about the TPMS, can I just run without them? Lastly, if these won't work can someone tell me exactly what I need to look for? I will be running in BS.
Thanks,
Cindy
Old Jan 11, 2006 | 09:57 AM
Nemesis8's Avatar
Bigus Rotus
I'd ask Brian Goodwin for advice. He is running Enkei RP-F1 18x9.5 with 45mm offsets and 275/35/18 Falken 615Rts.
Wheels are 17.2 lbs each!
Old Jan 11, 2006 | 10:00 AM
Dark8's Avatar
Ride Naked!
You need 18x8 wheels with 44-56 mm offset to be legal in BS. Don't worry about TPMS.
Old Jan 11, 2006 | 10:14 AM
Nemesis8's Avatar
Bigus Rotus
Oh, that's right, Brian is running STU isn't he?
Old Jan 11, 2006 | 10:24 AM
NoCones's Avatar
You down with 13B?
Your best bet is probably to buy some stock wheels from someone who went aftermarket for the street.
And, yes, for BS, you need to stay with 18x8 and within 1/4" of 50mm offset...no need for the TPMS
I use a set of stock wheels and a set of Enkei RPM2's for BS autox.
Modified Dave
Mar 5, 2016 04:36 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
fasdude
Jul 31, 2002 02:34 PM
