my rx8 is running lean i think please help
Old Jan 8, 2006 | 10:40 AM
toca's Avatar
howdy just went to the dyno today and it sucked i have a turboxs exhaust bb cat pipe and hks intake and only ran 177.3 hp and 120.0 tq on a 6 speed with 7500 miles on it but the thing i think is the problem is from 2 to 6 k my a/f raito is 14 .5 to 13.5 but at 7000k it drops to 11.5 the guy at the dyno said thats the reason for the low numbers any ideas what problems this can be he blives it my hks intake is not providing anough air presure to the air mass cencer he said its getting the valume of air maybe just no the pressure, any one have this problem or know what could be causing it like mass flow sencer, 02 cencer, spark plugs, etc please help
Old Jan 8, 2006 | 03:41 PM
toca's Avatar
i just did a full kam nvam pcm ecu rest car is running a lot better now can feel a big tq dif so ill be heading back to the dyno next week
Old Jan 8, 2006 | 06:50 PM
I'm afraid that that is relatively normal results depending on conditions.
The 11.5 AFR in open loop at WOT is normal...so is the 13.5-14.5 closed loop before 5.5Krpm.
You should dyno a bit higher after it has run in a bit more...but depending on the dyno that isn't that bad
Old Jan 9, 2006 | 01:17 PM
MadDog's Avatar
Consiglieri
Yep. Totally normal AFR. And, btw, the condition you are alarmed about is 'rich' not lean.
Old Jan 9, 2006 | 03:51 PM
Chrisbert's Avatar
We could use some lean'age. We run pig rich mostly.
Old Jan 9, 2006 | 06:30 PM
toca's Avatar
11.5 is rich ? im new to fuel raito so 11.5 is richer then 14.5 ?
Old Jan 9, 2006 | 06:36 PM
guy321's Avatar
Humpin legs and takin nam
Yes, it's much more rich than 14.5
Old Jan 9, 2006 | 06:48 PM
toca's Avatar
ok
Old Jan 9, 2006 | 07:00 PM
MazsportScott's Avatar
Mazsport.net
The Inteceptor-X ECU will allow you to tune the AFR's and adjust the timing to maximize your components and increase power!
Old Jan 9, 2006 | 07:04 PM
toca's Avatar
so then do u guys think im running to rich
Old Jan 9, 2006 | 07:06 PM
toca's Avatar
i do plan on buying 1 but i want to do a few more things first and about the the ecu of your what kind of power will i see na im trying to get the most i can from na
Old Jan 9, 2006 | 07:28 PM
RX8 Brunei's Avatar
Rotary Lover
From: Brunei: Where Ricers show off their fugly rides
The higher the AFR figure, the leaner you go.
Old Jan 9, 2006 | 07:32 PM
RX8 Brunei's Avatar
Rotary Lover
Other than tuning the AFR. Will the Interceptor-X fix my problem of "system lean"?? https://www.rx8club.com/series-i-tech-garage-22/p0171-system-too-lean-78270/
Old Jan 9, 2006 | 09:40 PM
joon's Avatar
strictly rotory
hey scott just wondering if you have to disconnect the two speed sensorsto the rear wheel prior to dynoing car?
Old Jan 9, 2006 | 10:10 PM
toca's Avatar
ok what this 2 wheel thing i heard it lowers the dyno numbers but my car doesnt have traction control is there somthing i need to disconect to get my real power gains
Old Jan 10, 2006 | 02:28 PM
MadDog's Avatar
Consiglieri
yes.....the exhaust manifold so you can install A TURBO.
Your power numbers are correct. They are totally in-line for this car. There is nothing wrong with your car or the dyno - only your expectations.
Old Jan 10, 2006 | 02:32 PM
Mazsport.net
No you do not.
Old Jan 10, 2006 | 02:34 PM
Mazsport.net
Originally Posted by RX8 Brunei
Other than tuning the AFR. Will the Interceptor-X fix my problem of "system lean"?? https://www.rx8club.com/showthread.php?t=78270
You should be able to tune the lean problems out of you setup with the Interceptor.
Old Jan 11, 2006 | 07:02 PM
toca's Avatar
i still think these numbers r quite low for my car with no cat a exhaust and intake is the cel from my cat pipe hurting my performance oh this numbers where on a dyno jet and i read that stock ones put from 180 to 185hp and 130 to 140 tq on these i post my dyno street so u guys can see the fuel curve
Old Jan 11, 2006 | 07:40 PM
toca's Avatar
well i cant get the pic file s,all anough i take th epic with the other camra later u think after 7500 mile my plugs r bad or fuel filter is bad or just the cel light from my cat pipe is telling the motor to run at lower out put
Old Jan 11, 2006 | 08:05 PM
Moostafa29's Avatar
Storm Trooper
toca, I think the best way to interpret a dyno in your situation would be to do a before and after. Not every car is going to be the same. Some completely stock cars dyno at over 200whp, and some at 170whp. If you want to see how much you have gained on all your mods, do a dyno with it back at stock, and then with your current mods. Try not to look at the final number, but the difference it gets you. But also, unless you tune you ecu for your mods, you more than likely won't see a huge difference anyway. Sorry to burst your bubble.
Old Jan 11, 2006 | 08:11 PM
RX8 Brunei's Avatar
Rotary Lover
Good. Then i'm going for it if my problem unsolved. But have to save some cash for a while.
Old Jan 11, 2006 | 08:25 PM
Sea Ray's Avatar
Also keep in mind not all Dynos are the same, or the guy operating it. With that in mind, use the same one for all your tests.
Old Jan 12, 2006 | 03:31 AM
IZoomZoomI's Avatar
Boost needed
The cat or lack thereof would actually lean out fuel curve a little bit so it would actually help.
But don't be surprised man . I wasn't at all when you told me those numbers. An exhaust is not going to make you run 200 whp for one hope you weren't dreaming about that if you were I can see your frustration. I think the rx8 in california are on a different flash that probably provide less power due to emission requirements. That could be complete bullshit though but hey it's an excuse.
That header you're planning on getting isn't going to change much either, you need proper tuning, tune the afr's as you please the leaner you go the more hp you would get. Nothing is wrong with your car just accept it.
OR just do what the above poster say and get a turbo in there, only way for now.
Old Jan 12, 2006 | 07:49 AM
toca's Avatar
only thing that makes me feel there is something wrongs is that i seen a dyno of someones turbo rx8 on here at 8 to 10 psi running 11.5 just funny how my stock car does 11.5 at 7k plus
