Alternate Flood Start procedure
Old Dec 17, 2005 | 08:23 AM
John Corbitt's Avatar
I came back in town last night to find my car flooded. Our line guy Didn't remember the 5 min rule. This is the second time it has happened to me where the manual's procedure did not work.
My alternate procedure has worked every time including on the older RX-7s. I just have someone pull me at about 20mph. ease the clutch out in second gear and after a few seconds give it a little gas. It works every time.
John
Old Dec 17, 2005 | 08:29 AM
r.ford1's Avatar
I've read in another post that a 9V starter, and a stronger battery completely eliminates any flood issues on the rx-8. You may need spark plugs to.
Old Dec 17, 2005 | 01:12 PM
BunnyGirl's Avatar
I read somewhere also that the 2004s are the ones with that problem and that they made a few changes and it is mostly fixed in the 2005s and later.
Old Dec 17, 2005 | 11:06 PM
kraji's Avatar
i had the same problem but after i got beefier starter with new spark plugs i never flooded again.
Old Dec 17, 2005 | 11:16 PM
nokiafan88's Avatar
this is good to know, i hate it when my old turbo II flooded like crazy
Old Dec 19, 2005 | 12:11 PM
fredw1's Avatar
Happened with my '05, so not just an '04 problem. I must have done the same thing (move tha car into the garage after washing) 15 times with no problems, but on #16, no start the next day.
Old Dec 20, 2005 | 10:38 PM
garynjr's Avatar
I was told that you should Rev the engine up to about 5K and shut off the car as you release the gas and that will burn up the fule trapped in the chamber...
Has anyone heard that? Thanks.... Perspective 8 buyer.... That's the only thing that's scaring me... I am a photographer and have had plenty of times when I need to move my car a short distance. Getting stuck with a flooded engine could really hurt. Thanks, G.
Old Dec 20, 2005 | 11:15 PM
Blue87Sport's Avatar
Rotary only since 1980
garynjr, the flooding issue arises when the engine is cold. If you've driven it and its up to temperature, moving short distances isn't a problem. Its only when the car sits overnight or for several hours in a cold climate.
Anyone with a good dog avatar deserves a response.
Old Dec 21, 2005 | 10:16 AM
garynjr's Avatar
Thanks... Yeah, That's Zeus... He unfortunately won't be able to fit in an 8 if I do actually get one... Not very Gracefull. He's about 150 lbs and very tall... Maybe I'll be able to teach him to sit upright instead of laying down on the back seat... Not that I really want him slobering up the leather...
Anyway, I live in a moderate climate... Cold winters, hot summers. PA.
Thanks... G.
Old Dec 21, 2005 | 10:28 AM
Moumtz's Avatar
You rev a cold car to 7k RPM? I hope your engine lasts. The manual specifically says do not rev above 4000 RPM until your engine is at normal operating temperature.
Old Dec 22, 2005 | 07:32 AM
I remember the "pop Start" in the RX-7 manuals. I don't recall an advisory against it in the 8 manual. I belive the warning was for the catalytic converter. I never had a problem with any of them "pop starting".
I was in PA for a short time in 1989. It was so cold, my FL RX-7 starter would not start the car. I parked facing down the hill every night and "pop started " it every morning. I sold that car with almost 200,000 miles on it with no engine problems.
John
Old Dec 22, 2005 | 08:03 AM
yiksing's Avatar
the giant tastetickles
So do you have to turn the ignition as u ease up on the clutch or after you give it some gas or not required at all?
Old Dec 23, 2005 | 08:42 AM
msrecant's Avatar
Hubble has been saved!
No true.
Old Dec 23, 2005 | 08:45 AM
msrecant's Avatar
The new starter, battery and plugs dramatically improve things but there is no conclusive evidence that this totally eliminates the problem. I believe Mazda still recommends that the engine should not be shut off cold.
Old Dec 23, 2005 | 08:54 AM
msrecant's Avatar
The QUICK TIPS (the small booklet that came with the owners manual) warns against short trips. If you have to make a short trip it recommends: start and let idle for 10 seconds, move the car, let the car idle until normal engine temp or for 5 minutes, rev to 3K and hold for 10 seconds, let return to idle and turn off the engine. This is the same warning/procedure shown in the Product Update DVD distributed this year.
Check out https://www.rx8club.com/showpost.php...&postcount=954.
Old Dec 24, 2005 | 12:40 PM
Turn the Ignition on when you start to be towed.
John
Old Dec 25, 2005 | 01:43 PM
capitolgator's Avatar
mine flooded recently; Mazda towed it in, replaced the old starter with a new one and a beefier battery (free of charge) and I was told it will never flood again... so far so good.
Old Dec 25, 2005 | 11:22 PM
amartin's Avatar
Well.thats BS..it'll flood. Mine did on X-mas... The RX-8 is a piece of sh*t.
I wish to GOD I had never gotten this car.
Old Dec 27, 2005 | 06:29 AM
Charles Cope's Avatar
Sounds like its time to move on.
Old Dec 27, 2005 | 06:17 PM
marcussmith26's Avatar
hey guy need some help.my little brother just got a 05 rx8 ,it quit starting so we pop started it and it was smoking like cazy and started making a knocking sound ,sounds really bad, any ideals what migth have happened its just got like 8000 miles help if you can
Old Dec 27, 2005 | 08:53 PM
msrecant's Avatar
Did he shut off the engine without letting it warm up? Mazda warns against that. See https://www.rx8club.com/showpost.php...3&postcount=17.
Old Dec 28, 2005 | 11:40 AM
What Octane fuel are you running. It will run on 87, but I have noticed running a higer octane fuel leaves less carbon deposits on the rotor and the run better. I prefer Chevron of Amoco.
As the older RX-7s got more mileage on the they got more finickey. I they didn't get the 91 fuel, they were more likely to flood.
John
RXeckless
Aug 16, 2015 12:52 PM
RXeckless
Aug 16, 2015 12:51 PM
harithac
Jul 25, 2015 04:21 PM
thedragonrotar
Jul 22, 2015 08:46 PM
