clunk noise - coilovers or RB sways?
Old Dec 10, 2005 | 08:12 PM
RL8's Avatar
RL8
I just had my JIC coilovers and RB sway bars w/ RB end links intalled today and I'm having this loud clunking noise coming from the front passenger side whenever I go over bumps or driveways. Not sure if it's a spring binding noise, it sounds louder then that. I re-checked everything and they look fine, not a sign of scratch of the components. What should I look into next? Thanks.
Old Dec 11, 2005 | 05:02 AM
Go48's Avatar
Re-torque the sway bar bolts/nuts to specification. Also do a search of the forum for threads dealing with this specific "problem".
Old Dec 11, 2005 | 05:09 AM
the lugnut torque spec was revised from 88 lb-t to 108 lb-ft to address front wheel clunking, be sure to check this to
Old Dec 13, 2005 | 12:08 AM
RL8's Avatar
RL8
Thanks. The car seems fine now after a couple hundred miles. I'll re-check everything when I do the alignment.
duworm
Oct 1, 2015 04:57 PM
Racingjunkie
Sep 29, 2015 05:05 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
