where did u input neutral switch w/ compustar?
Old Nov 7, 2005 | 09:38 AM
irfan's Avatar
ElusiveSasquatch
im going to put my compustar into automatic mode because its much more convenient (eg i can get somethign out of the car without having to reset reservation mode).. the only problem is that the compustar doesnt seem to have a neutral switch input (2w900fm),, if anyone installed their manual on a compustar system, please let me know what wire on the compustar you connected the neutral switch to.
Old Nov 7, 2005 | 10:07 AM
irfan's Avatar
ElusiveSasquatch
if there isnt an input at all tell me how this sounds:
i do NOT bypass clutch with starter wire, instead i jsut connect the starter wire from remotestart to the wire @ ignition harness,
take neutral safety wire and input to pin 86 on relay,
fused 12v on 85.
87 is key side of starter wire @ clutch,
30 is starter side of starter wire @clutch.
87a unused.
this way, the clutch should only be bypassed when the car is in neutral correct? neutral= 87 connects to 30. in gear = relay open... unless im in the car and stomp on the clutch pedal.
TheWulf
Nov 29, 2011 08:57 AM
TheWulf
Sep 29, 2009 11:16 PM
phobi
Canada Forum
16
May 11, 2009 10:53 AM
huhsler
Jan 12, 2004 11:04 AM
