View Poll Results: WHAT TYPE OF GAS DO RX8 OWNERS USE
SHELL
46.43%
EXXON
3.57%
BP/AMMOCO
10.71%
OTHER
41.07%
Multiple Choice Poll. Voters: 56. You may not vote on this poll
what type of gas do rx8 owner use
Old Oct 30, 2005 | 01:05 AM
mauricio's Avatar
Post what type of gas do rx8 owner use
what type of gas gives you better gas milage to performance.
SHELL,CHEVRON,TECHRON and other not major brand name gas have better detergents than EXXON OR BP which are the two major distributors
Old Oct 30, 2005 | 01:11 AM
Rudsther's Avatar
I use 76, or chevron
Old Oct 30, 2005 | 01:20 AM
Asmoran's Avatar
I use shell V-Power cuz it's right by my house. Otherwise I'll use any of the name brand stations.
Old Oct 30, 2005 | 01:37 AM
NgoRX8's Avatar
I use Shell because it is cheapest in my area, but I have no idea which gas would give better mileage or performance. I don't think they give major differences in either... at least they shouldn't.
Old Oct 30, 2005 | 04:06 AM
Krankor's Avatar
Klingon Grammarian
I use Mobil because it is literally next door to me, and because I love the speed-pass thing. I also have yet to be convinced that the brand makes a big difference in performance or mileage, but I'm willing to be persuaded.
--edit-- Oh, also because it's 24 hours. I'm a night-owl.
Old Oct 30, 2005 | 04:24 AM
Rotor Kreuzer's Avatar
The 8th Deadly Sin
No other choice but Shell for us 8 owners here in Brunei.
Old Oct 30, 2005 | 08:22 AM
CaptDharma's Avatar
Dont Fear The Reaper!
Which Octane do all of you use?
Old Oct 30, 2005 | 08:52 AM
TRZ750's Avatar
The EPA mandates some cleaning elements in all fuel. Many actually use the same chemicles, but there is some variations in treatment rate.
Old Oct 30, 2005 | 09:11 AM
conedodger's Avatar
Conedodger
I use Sunoco. I run their 87 in my 8 w/ no problems at all. It also helps that I get 4% back w/ my Sunoco Mastercard.
Old Oct 30, 2005 | 10:13 AM
Labop's Avatar
Most of the time it's Citgo, it's what the Navy Exchange uses in it's gas stations. When I'm off base it's Shell v-power.
Old Oct 30, 2005 | 10:33 AM
lesper4's Avatar
T-29 years and counting
I usually try to get Shell being the cheaper gas around and of better quality. The other probelm is I use credit card for all my payments so on ocasion I get Mobil and on very a rear ocasion I get Arco when it has a credit card spot, (the new ones do). I always get medium grade which is usually about 89 octane but at Arco I think it is less. While gas prices have begin to fall I have been thinking about getting preimum.
Old Oct 30, 2005 | 11:17 AM
sunilseru's Avatar
I tried Shell and Mobil. Shell gives me better mileage and costs the same.
Old Oct 30, 2005 | 11:31 AM
Fanman's Avatar
Shell, or Exxon. I use 91 all the time (best you can get here in California).
Old Oct 30, 2005 | 02:35 PM
Discman2's Avatar
Rotary Noob
It's all the same gas.
but the octane I use is 93
Old Oct 30, 2005 | 04:56 PM
NgoRX8's Avatar
Yup 91 octane aka Shell V-Power
Old Oct 30, 2005 | 05:30 PM
goforwand's Avatar
Raced with Joy & Abandon
93 Shell V-Power, always
Old Oct 30, 2005 | 07:26 PM
Daddy_G's Avatar
I used to use any name brand in the area, but last month, at 21000mi the car started missing at low rpm. I took the car to the service department where they replaced the plugs. They said the plugs were fouled due to what they thought was bad gas and told me that they recommend Chevron high grade only. So, its Chevron for me.
Old Oct 31, 2005 | 01:38 PM
wisconsinben's Avatar
Black and B-E-A-UTIFUL!
Shell...89 octane. Every once in a while I'll run a tank or two of premium (93 octane) in hopes of "cleaning" things out, but my gas mileage suffers...about 2 mpg less.
Old Oct 31, 2005 | 01:53 PM
Y&Y's Avatar
Y&Y
Actually from what I've heard is that if you keep using different brands at every fill up is bad. And in Daddy_G's case, the gunked up spark plugs was the end result. Since each major brand uses a slight different blend in their gasoline, and what would probably happen was that the different chemical properties between the different blends coagulated the spark plugs when introduced to high heat. Well at least that was what a honda mechanic told me years ago. So since then I would try to stick to the same brand.
I'm still wondering about Arco though. Years ago they were busted for watering down the gasoline. And supposedly they cleaned up now. So does that mean Arco gas is on par with other major brands?
Old Oct 31, 2005 | 02:12 PM
my car only likes 91 76
Audio Concepts ATL
Sep 26, 2021 01:59 PM
Skyl3r
Dec 2, 2019 04:51 PM
RXeckless
Aug 16, 2015 12:51 PM
whitelight42
Aug 6, 2015 01:10 AM
Bamaham
Jul 23, 2015 08:08 AM
