OBX RX8 Header
Old Oct 2, 2005 | 12:37 AM
Jabberwock's Avatar
OBX RX8 Header
OBX Header
http://cgi.ebay.com/ebaymotors/OBX-E...04383069QQrdZ1
I know OBX makes pretty crappy stuff, but its a cheap header compared to what is out there.
Any opinions if it would make any power gains or is it worthless?
Old Oct 2, 2005 | 12:56 AM
expo1's Avatar
He's as bad as Can
Well if the $1,000 header's only give a 2-3 HP boost whan can you expect from a $287 one??
You get what you pay for
Old Oct 2, 2005 | 01:02 AM
ok who wants to be the test mule?
Old Oct 2, 2005 | 01:04 AM
ddub's Avatar
always preoccupied.
It's probably just a copy of one of the $1000 ones. That's what these companies do, buy one, make a mold or design for replication, sell the expensive one, and begin production on their knockoff versions. Shouldn't be a change in power if this is the case, change in quality, though, is another story. Lots of times these cheap ebay exhaust parts use thin walled tubing.
Old Oct 2, 2005 | 02:18 AM
Jabberwock's Avatar
I thought some of the $1000+ header make a little more than 2-3hp depending on design.
Any experts know if the OBX Header design would make much of a hp or torque difference.
Old Oct 2, 2005 | 03:00 AM
well at least they are not making any claims for hp with it.
coupe07's Avatar
SC 300HP!!
an authentic header from japan will give u 5-10 horses.......
10 horses for the 6mt, 5 horses for the 4AT and 5MT
Old Oct 2, 2005 | 03:12 AM
rotarenvy's Avatar
I doubt this is a more you pay more you get situation.
Old Oct 2, 2005 | 03:55 AM
IZoomZoomI's Avatar
Boost needed
^^^ agreed. I rather pay 287 and get 1hp than pay 1000 to get 2-3.
Old Oct 2, 2005 | 09:12 AM
therm8's Avatar
Bummed, but bring on OU!
i'd like to see that...then I might believe it. Equal length headers won't give you such gains on the renesis. And all the headers I've seen from Japan were equal length.
$43 for s/h? Seems a little high. A bit more handling than shipping I'd bet :p
Old Oct 2, 2005 | 10:39 AM
Jabberwock's Avatar
A lot of ebayers are high on shipping.
I agree that $287+$43 S/H is a lot cheaper than over $1000 + shipping from japan.
Old Oct 2, 2005 | 04:27 PM
rotarenvy's Avatar
these ones are closer to equal length than most of the ones from .jp.
the knightsport ones look far from equal but seperate the centre ports;
the obx ones look like the re amemyia ones and look equal length;
the FEED have longer runners and are also fairly equal in length by the look.
Old Oct 2, 2005 | 05:38 PM
therm8's Avatar
They may not all be equal length, but all three runners collect at the same point, which doesn't make sense harmonically when you consider the siamesed center port. It's runner should collect further down theoretically to make the most of the pulse tuning. Knightsport looked like they were heading the right direction.
This is from a much older discussion: (there was a much, much older one but I can't find it)
Originally Posted by rotarygod
Racing Beat played with a split center runner and found that it didn't do any better than the conventional 3 runner header. That is really strange to me. They did say that the header designs that they tested did about 4-5 hp more but only at the peak point. I still need to build my header design to see if it has any merit. It might not work but I won't know until I try it. The 2 outer runners get collected at the same length. The center runner is 50% longer and connects downstream of them. Off of this center runner is a dead leg pipe to nowhere that is the same length as the outer pipes but blocked off. This is purely for resonance. I have no idea if it would work on the Renesis but on older 4 cylinder piston engines that had siamesed center runners, they did this on the race cars. The original mini was one such vehicle. It worked there. One way to find out I guess.
I do have another thought as to why headers aren't doing much on this engine. Part of it could do with the fact that we have no overlap and therefore no scavenging that can help pull in more intake charge. The other thought is that the exhaust ports right now just don't flow any better than even the stock exhaust manifold and that any increase in flow in the exhaust system really won't do much. I really wonder how a set of headers would do on a ported engine?
for $330 it may be worth a shot, at least you might have something to experiment on when there are little to no gains. The problem with the "ideal" harmonic design is that it would take up alot of space, and space is hard to come by under the car.
Old Oct 2, 2005 | 06:01 PM
r0tor's Avatar
seems to me will all of these headers the O2 sensor will only ever be monitoring the rear rotor (?)
Old Oct 2, 2005 | 06:26 PM
ddub's Avatar
always preoccupied.
$249 + 32 in this auction that was just started today
http://cgi.ebay.com/ebaymotors/OBX-R...spagenameZWDVW
Wonder how long before all the car part ebay power sellers are selling them and having a battle for the lowest overall price. Should be interesting.
Old Oct 2, 2005 | 06:59 PM
miraclewhip's Avatar
how many headers do we need for our cars..... do we need 2 ???
Old Oct 2, 2005 | 07:02 PM
ddub's Avatar
always preoccupied.
We need 1 header...
Old Oct 2, 2005 | 10:19 PM
ooo so we don't need one header per rotor chamber..??
Old Oct 2, 2005 | 10:21 PM
ddub's Avatar
always preoccupied.
Please do research, and look at pictures of the engine and then look at the pictures of the header that were posted in this thread, then think about your question again.
Old Oct 2, 2005 | 10:27 PM
pimp20g's Avatar
that obx header actually look slike a pretty good design. Plus the welds look nice. I think someone should try one, or give me the $300 and i will try it....
Old Oct 2, 2005 | 10:29 PM
ddub's Avatar
always preoccupied.
I'm actually thinking about buying it to give it a shot... I'm going to get a catback and midpipe first, though, and will probably hold onto them until I get the header (if I decide to) so I can do the whole install at once.
Old Oct 2, 2005 | 10:43 PM
therm8's Avatar
midpipe will give you pretty good gains, i'd do that first (or last) so you can get a better idea if the header works.
Old Oct 3, 2005 | 07:27 AM
Jaguar_MBA's Avatar
This header does not look crappy. What is crappy is paying ~$1000 for 1HP gain. That is what somebody Dynoed at with a header on this site.
Old Oct 3, 2005 | 07:41 AM
tuj's Avatar
tuj
The OBX headers for the Miata were initially much maligned until people realized they were really pretty decent, and about half the price of the competitors.
Old Oct 3, 2005 | 02:24 PM
KYLiquid's Avatar
Oil Injection
I have seen and installed a few OBX headers on differnt cars.
I had one on my 99 miata, I got it for 100 used.
The quality of the header was great, nice welds, nice thick tubing, it was all stainless steel with ceramic coating, looked good, smooth bends, nice cut flange, ect.
I would say they make a good product.
The problem with the OBX stuff was always the FIT, they never fit quite right, rather than bend the tubing on the header, we could always bend the firewall a bit, or make a small dent in a rail, whatever, to make the header fit.
The fit was never really bad, off by maby 1/8-1/4 inch....so it wasnt much work.
It would bolt up fine, just that it would rattle agaisnt the frame or firewall, causeing noise and vibrations. So if you dont mind a little time to knock it in place, it isnt a big deal IMO.
My concern with the RX8 would be the placement of that O2 sensor, in just 1 of the pipes, not the colector, and the fact that the exhaust on the motor is VERY hot, and you wouldnt want it as close to the body/frame as you might try with a piston engine.
I would get one and ceramic coat it and/or heat wrap it...just to be safe.
