Midepipe cel problem, fixed!
Old Sep 23, 2005 | 04:04 PM
modena's Avatar
Modena
Many thanks to a fellow member of this board for a simple and cheap fix!
No more cel lights due to an installed midpipe.
Fix was easy: small adapter fits between the 02 sensor and you are good to go.
(The Casper electronic fix did not work)
Thanks “gtaw”
Here is the tread where I found it:
https://www.rx8club.com/series-i-tech-garage-22/solution-cel-midpipes-racepipes-64222/
Old Sep 23, 2005 | 10:05 PM
thanks, I had been looking for that thread and wondered what ever happened to that guy
Old Sep 24, 2005 | 09:20 AM
cgrx's Avatar
DRIVEN
^^ me too
How many miles traveled w/o CEL ?
Old Sep 24, 2005 | 09:34 AM
modena's Avatar
Modena
160 now,
Before the adapter, cel came on at about 24 miles.
Happened 3 times...
(Disconnected the battery for about 2 ours each time to reset light)
Tried the Casper electronic unit and cel came on in 5 miles.
Remove Casper unit and installed adapter, seems to be "cured" now...
The guy I got it from ships fast, ask him and you should be golden next week
This is how it looks like under the car...
(Not my picture)
Old Sep 26, 2005 | 04:08 AM
RX8PDX's Avatar
I had a 02 Subaru Impreza, that I put an exhaust on. Got a CEL probably for the same reason.
I got one of these adapters, and it worked for about 50 miles.
So good luck, I hope it works for you.
RevMeHarder
Jun 1, 2026 02:30 PM
DVerdeyen
Sep 13, 2015 11:19 AM
ed0128
Sep 9, 2015 04:50 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
Octomus
Sep 3, 2015 11:40 AM
