Brake Light Keeps Coming on
Old Sep 17, 2005 | 08:04 PM
urby1970's Avatar
Old but Proud
I periodically get a brake light comes on for no reason, it's like I have my emergency brake on light. Then driving down the interstate it will all of the sudden go off, then later it will come on again. Anyone experienced this?????
Old Sep 17, 2005 | 08:34 PM
Check the Master cylinder fluid level...probably a bit low. You might want to check your brake pads ...esp the front pads for wear......
Old Sep 17, 2005 | 08:49 PM
urby1970's Avatar
Old but Proud
Thanks I will check it out. If I can't find the immediate problem, I will take it in. I need to take it in for the recall anyway. Thanks!
Old Sep 18, 2005 | 12:29 AM
Shifty Devil's Avatar
Think this is related to that sticking/stiff brake handle boot problem others have noticed (even though that is usually a winter problem)?
Old Nov 3, 2010 | 08:48 AM
fastlane425's Avatar
fastlane425
same
ive been having the same problem and i was just wondering if you ever got it fixed.
Old Nov 3, 2010 | 11:02 AM
lilring's Avatar
Finally a MT
i had the same problem, but all it is, is that the pads are low which causing the brake fluid to be low and set the sensor off. So get new brake pads
talonhart2
Aug 26, 2015 04:14 PM
Kahl
Aug 20, 2015 11:49 PM
rx8wankelrotary
Aug 17, 2015 10:42 AM
MarkX
Jul 31, 2015 07:50 AM
Jmanie9515
Jul 20, 2015 07:29 PM
