2005 RX8 recall
Old Sep 16, 2005 | 08:32 PM
Mzdarx8's Avatar
Exclamation 2005 RX8 recall
Just had the thermal recall done on my 05. Took about 2 hours. Mechanic said every thing looked good and this was there first with a racing beat exhaust and rotary performance cat. He said they did 4 8's and all had no heat related issues! Good news to me!
Had the ecu flashed for the first time. Still confused on what flash i am at? Forgot to ask. Work order does not have it. The sticker on the door jamb says campaign #3305G. What flash letter are we at on the 05's? Any one know?
Old Sep 16, 2005 | 10:47 PM
ernurse's Avatar
I just bought my RX 8 several days ago. What is the recall for? I am new to this car....
Old Sep 17, 2005 | 06:35 AM
Go48's Avatar
There are several, but one would assume that the dealer did them before delivering the car to you. Ask them. Also, do a search of the forum for "recall" and you will find out more than you really need to know. Most of them will not involve a 2005, however.
Old Sep 18, 2005 | 09:50 AM
Labop's Avatar
I was quoted two to five hours, but I talked the guy into bumping it up and getting it done quick (I'd been awake for 26 hours and had just gotten off of work). I was originally told that it would take a day and I'd get a rental. But there were no rentals, and they don't do courtesy cars.
Know how long it took? 34 minutes to perform the heat recall and inspect the ball joint.
Old Sep 19, 2005 | 04:24 PM
ernurse's Avatar
Thumbs down
Well The dealer had not done the recall. D--- dealers. funny thing is this is after that letter to the dealers. I just took delivery on 15 Sept..... Something is wrong with this picture.....
Old Sep 19, 2005 | 06:30 PM
Gomez's Avatar
Shifty Bastard.
Relax. Cars built later than the 7th July 05 don't need a recall. Do some research on your build date before you jump to conclusions.
Old Sep 19, 2005 | 08:23 PM
red61's Avatar
Black '05 RX-8
How do you find out when your car was built? Also, could someone explin what getting the "flash" means? Is this part of regular maintenance or something you have to ask them to do? I have an 05 I bought in August.
Old Sep 19, 2005 | 08:25 PM
Mzdarx8's Avatar
Here is the site for the service bulletins,
http://www.finishlineperformance.com...ins_index.html
Hope this helps!
Old Sep 20, 2005 | 07:23 AM
ernurse's Avatar
Mine was built October 2004........ Dealer just disregarded Mazda letter.
Old Sep 21, 2005 | 06:34 AM
cardoc01's Avatar
The Doc is in
as to the ecm flash with the recall seems some people like to sit still and rev the engine over 8000 rpm hmmmmm well this pcm flash is suppose to limit rpm rev time at a standstill ie: not rolling, to 8 seconds, then it will return to idle even if you have youre foot in it!! that is what was melting the gas tanks, too much heat, no air flow
akagc
Aug 11, 2015 07:07 PM
Rx808BI
Aug 9, 2015 10:06 AM
Quato_jr
Aug 4, 2015 09:22 AM
MauiMazda2
Aug 3, 2015 02:47 PM
netrovers
Jul 20, 2015 03:32 AM
