I'm facing a problem with the EPS!
Old Aug 15, 2005 | 05:50 AM
Daverx's Avatar
tHe mOd-DeR
I'm now experiencing a problem....whenever my ride is parked overnite or for several hours, I have difficulties with the steering....It vibrates vigorously! & very stiff to go either left or right!
I've to stop & roll the steering left to right, right to left & left to right........ to let it vibrates for a while & everything will be back to normal! What's happeneing?????
Something wrong with the EPS? Anyone experienced this, I doubt. What about those rides not from Singapore???
Old Aug 15, 2005 | 06:06 AM
Daverx's Avatar
tHe mOd-DeR
I've checked with the techy forum....was told that to reset or calibrate the EPS.....
Any bros noe how to do it? thks..............
Old Aug 15, 2005 | 06:09 AM
M-ster's Avatar
wats EPS?
Old Aug 15, 2005 | 06:21 AM
Daverx's Avatar
tHe mOd-DeR
Originally Posted by M-ster
wats EPS?
Electric/Electronic Power Steering......
Old Aug 15, 2005 | 06:28 AM
M-ster's Avatar
Duh! silly me...
Anyway... sounded serious!
maybe try disconnecting your battery. that will reset a couple of electronics. Unless you know exactly which fuse to pull out...
Old Aug 15, 2005 | 06:33 AM
Daverx's Avatar
tHe mOd-DeR
Duh! silly me...
Bro.. thanks...
hmmm....maybe will try to....
i've posted this problem at the tech section hopefully our 8s bros overseas can assist..... seemed some oreadi faced problems regarding the steer but not the vibration part......
keep my fingers crossed!
thanks bro :p :p :p
Old Aug 15, 2005 | 06:41 AM
M-ster's Avatar
If you really pulling the battery, remember this, the DSC light will come on, to dis-enage, turn your steering all the way left then rigth (or the other way round cant remember) that will re-set the DSC.
And hopefully the EPS too....
good luck
Old Aug 15, 2005 | 09:11 AM
Genesis's Avatar
Driving Me Crazy
Daverx...not really sure what would cause that to happen, but the 8 does benefit from a decent electrical grounding like circle earth from HKS....just a thought.
Old Aug 15, 2005 | 11:38 AM
coupe07's Avatar
SC 300HP!!
zavhan had that problem before... some electrical fuse i tink.. u may wan to check with him
Old Aug 15, 2005 | 08:28 PM
Daverx's Avatar
tHe mOd-DeR
roger dat.............
thanks bros......i'll do & check what u guys have suggested.....hopefully it works.....else .......*sigh* :p :p :p
Old Aug 15, 2005 | 11:13 PM
2F2F's Avatar
same ****
Hi Bro,
Yeah, I'am having the same problem. Already spoken HY workshop at Ubi and they will contact the Jap to understand what cause this.
I have read some threads and they did mentioned to replace wire harness and Power steerring module to resolve the problem.
I will continue to chase them and call you once found out the cause.
Did you just change Battery!!
Old Aug 16, 2005 | 12:47 AM
Daverx's Avatar
tHe mOd-DeR
Originally Posted by 2F2F
Hi Bro,
Bro...thanks
same car same time having same problem.....
thanks
Digitz0070
55
Jul 25, 2017 08:40 PM
Zube6115
Sep 30, 2015 12:57 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Evan Gray
Sep 26, 2015 12:30 PM
