homelink help
Old Jul 17, 2003 | 04:31 PM
tribal azn2's Avatar
Lightbulb homelink help
i cant seem to get my homelink programmed. can anybody help?
Old Jul 17, 2003 | 05:07 PM
pelucidor's Avatar
Pure Gold
Does your garage door have a rolling code? If so you will have to train the homelink to switch codes in synch with the door opener - first part should be thoroughly documented in the RX-8 manual and the other part should be in the garage opener manual.
Usually it's something like: delete existing code on homelink, get on a ladder and press 'learning' button on door opener, run to car and set homelink for 2-30 secs etc.
Old Jul 17, 2003 | 05:09 PM
rx-ache's Avatar
I might be able. I have homelink in a Volvo. It depends on your garage door opener. If it is newer than about 10 years, you will probably have to do it this way.
First, follow the instructions in the RX8 manual regarding getting the remote signal memorized by the homelink. In the Volvo, I had to hold down the button on the home link while pressing the remote within a couple of inches. This allows the homelink to capture the signal.
Next you have to tell the garage door opener that you want it to work with that signal. I believe my Genie worked this way:
There is a learn remote button on the drive box. Press that once, then press the button you programed in step one (the homelink button). Your drive box should have an LED that lit when you pressed the "learn" button. That should either blink, or go out I don't really remember. You then press the homelink button and the door should move, press it again and the door should stop. You should be good then.
Read the instructions for your opener on how to program it for a new remote. Getting homelink to store the code (as is probably all that is in your RX8 manual) is only half the battle. Good luck.
Old Jul 17, 2003 | 05:17 PM
JaxFL_RX8's Avatar
Also, you have to unplug the door opener before you program the Homelink.
Old Jul 17, 2003 | 06:32 PM
what the hell holy **** , this is like brain surgery. all i did was hold the remote to the homelink and pressed simuntously and nothing happend.
Old Jul 17, 2003 | 06:39 PM
jd62's Avatar
Old Fart
Re: homelink help
Mine somehow got programmed before I took the car. Just press the two outside buttons and hold them in for a minute or two as the instructions say. That will remove any prior programming.
Old Jul 17, 2003 | 08:15 PM
whenever i hold the remote to the homelink and press both at the same time, that little LED light just stays red it doesnt flash or blink or anything.
Old Jul 17, 2003 | 08:18 PM
8_wannabe's Avatar
Go baby!
What you describe is how I programmed my wife's beemer a couple years ago. It worked. But I haven't read the 8 owner's manual yet; what does it say?
Old Jul 18, 2003 | 01:53 AM
pelucidor's Avatar
Pure Gold
Read my post. You have a rolling code garage door opener (code changes every time you open garage) which is common nowadays. Your method of setting is only good for fixed code door openers (i.e. code is always the same).
My last 5 cars had homelink. For each vehicle the manual said more or less the same thing - do X and then refer to garage opener manual to activate learning mode. Just RTFM - it will only take a few minutes.
Old Jul 18, 2003 | 02:24 AM
yea ima try that **** 2moro or this weekend. both cars need to be outof the garage so i can set up a ladder to reach the damn power plug on the ceiling. damn i wish they could make this easier.
Old Jul 18, 2003 | 11:09 AM
eccles's Avatar
Prodigal Wankler
BTW, you don't have to disconnect the power from the door mechanism - that's only to prevent the door going up and down while you're programming the system. If it's a major hassle, and you can live with a couple of cycles of your door opener, don't bother pulling the plug.
However, you will still need to access the remote receiver in order to press the programming button, per pelucidor's note.
Old Jul 18, 2003 | 12:07 PM
CraziFuzzy's Avatar
You are sleeepppyyyy.....
I messed with mine for a while, but i finally got it to work. Here's what i did:
First, you have to clear the Homelink's memory by pressing and holding I and III on the mirror until the light starts blinking rapidly. (like 20sec or so)
Second, program the homelink from your normal garage door opener by holding it right in front of the mirror and pressing the homelink button you want to program and the remote. This will program your mirror to act like your normal remote.
Next, I had to tell my garage door opener that it was okay to listen to this new remote, so i had to press and hold the homelink button, while someone else pressed the programming button on my garage door opener. (A red button recesed under the back light cover on my chamborlain). The light on the opener then blinked, indicating that it was programmed. The homelink button now works for my opener, and it actually has a further range than the cheesey handheld transmitter that came with my opener. I hope this helps you, if not, give me some more details on what kind of opener you have, and I'll try to get you some more help. I don't like the idea that someone is unhappy with ANYTHING in the 8... :-)
EDIT: OH Yeah, as another note... my opener could only be programmed with the garage door shut. Check the manual for your opener (if you have it) to find out if this is the case for you.
AccessoryMan's Avatar
For more information on how to program the HomeLink Mirror
http://www.homelink.com/home/home.tml
Old Jul 18, 2003 | 08:31 PM
thx guys, i finally got it.
i didnt have to do all that crazy ****. it turns out that u have to hold the buttons for a riduclously long time
Old Jul 18, 2003 | 11:29 PM
B-Nez's Avatar
Glad you got it worked out. So, are you gonna go nuts and install keyless locks on your doors and remote lighting in the house? I think I will be doing the keyless door locks in the near future, but the lighting stuff is pretty pricey. The main thing holding me back on the door locks right now, is that the Kwikset keyless lock does not come in a satin finish - only a dull brasstone. Maybe if I find another brand...
Edit: We just closed on a new house yesterday, so we're doing a lot of prep-work before we move in next weekend. I had to provide my own garage door opener, which was fine with me because I got exactly what I wanted: The Genie Excelerator Lifetime Warranty. It opens the door at twice the normal speed for those quick, batman-like getaways. :D :D
Old Jul 19, 2003 | 12:19 PM
8_wannabe's Avatar
Go baby!
thx guys, i finally got it. i didnt have to do all that crazy ****. it turns out that u have to hold the buttons for a riduclously long time
I wuz just about to tell u that. It takes at least 15 seconds holding both buttons before the light finally blinks. My problem: I got this to work for my garage door (which has rolling codes) and I didn't have to do any of that ladder stuff or anything at all with the door unit itself. It just works. But I have a second remote for the gate into my community and I can't get that one to work. I'm sure they won't let me unplug or push buttons or anything on the gate. And I didn't have to for my wife's car; just pushed buttons on the two remotes simultaneously and it works. I'm kinda stymied on the gate.
Old Jul 19, 2003 | 01:16 PM
CraziFuzzy's Avatar
something you might try is to change out the batteries in the gate remote. That is one of the recomendations on the Homlink site. It needs a real strong signal to program the homelink, so fresh batteries are the best bet.
Old Jul 19, 2003 | 01:49 PM
Magnesium's Avatar
Lurking troll
He forgot to mention that you have to hold your nose while you turn 270 degrees clockwise, then reverse your direction 480 degrees. At the completion of the revolutions, hop on one leg and chant something about your mom. That should do it.
Old Jul 19, 2003 | 03:20 PM
8_wannabe's Avatar
Go baby!
Haha, very funny. But I solved my problem. Hold both buttons till the homelink light blinks and KEEP HOLDING!! Then, it'll start blicking faster and you're done. Almost like what the instructions say if I had read them sooner. There is no need to find a horny toad in a hollow stump during a full moon or perform any of the incantations mentioned above.
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
vapor2
Jul 9, 2016 07:35 AM
RX-Aight
19
Dec 28, 2005 02:59 PM
portero23
Sep 14, 2004 06:59 PM
Pavehawk
10
Jul 17, 2004 07:31 AM
