SE RX-8 Forum Serving NC, SC, GA, FL, AL, TN
This big recall sucks
Old Aug 5, 2005 | 08:07 PM
valpac's Avatar
Ahead of its time
Originally Posted by djseto
I called Jim Ellis of Marrietta today to see if I could get the Spark Plug and Battery TSB done, but the service guy on the phone said if I bring my car in, they arent going to give it back. So until I get my recall letter for the Heat Shield/Gas Tank crap, I guess I have to avoid the dealer for any service issues. Anyone get a better idea?
Same dealer, different stories. I wish dealers were more consistent in their service "advising".
Jim Ellis told me they werent even going to do my recall unless I had letter in hand. They are doing cars in their inventory first (Imagine that). I called Mazda of Roswell and they said they would do it without the letter but would have to order the shield for my car. Today they called, part was in and wanted me to bring my car in. And I was, too. Until they told me my car would be their firstnot a guineau pig). Nope. I'll wait. Besides its not like I drive the car in the manner which causes the damage anyway. Not worried.
I dont think they can take your car hostage.
Old Aug 6, 2005 | 09:27 AM
valpac's Avatar
Ahead of its time
Do you really think you have damage? I had Charlie look at my body grommets for signs of deformation. None. So my tank is probably fine, too. I wouldnt worry about a long road trip w/o the recall done. At highway speeds (cooler running) you are least likely to have thermal damage than city driving. And damage in the city will only really happen if you are revving up at a light to drag.
Obviously, your call.
Old Aug 6, 2005 | 02:39 PM
legokcen's Avatar
The Turkish Delight
I can't think that I have much damage either, but I'll take the car in next week after I call my dealer. Hopefully they'll put on the R flash too.
Old Aug 7, 2005 | 07:24 PM
olddragger's Avatar
Yea I think those of us who put on cat backs actually helped this issue. I see no damage at all on mine and My suspension arms are the D series so I lucked out there also!
olddragger
Old Aug 7, 2005 | 07:46 PM
rxeightr's Avatar
M0D Squad -charter member
OD,
Where did you find out your arms are the 'D' series -- how could you tell?
Old Aug 7, 2005 | 08:09 PM
legokcen's Avatar
The Turkish Delight
Just a side note. After looking at the previous 3 posts, pretty soon, I think we're all going to have avatars from Track Day or HPDE sessions.
Old Aug 7, 2005 | 09:46 PM
Morgan's Avatar
Lounge Sweetheart
maybe i should call my dealer too...idk enough about the recall, but i'm guessing i ought to find out..plus i want the R flash.
Old Aug 8, 2005 | 04:24 AM
valpac's Avatar
Ahead of its time
You WANT the R flash? Have you read the service bulletin? It appears the R flash does nothing more than cut idle when engine is hot and operating for extended time at higher idle speeds. I can't see how this is much better the P and it seems worse as the flash is taking over idle control.
I guess want I'm getting at is not all flashes are "good" just because they are the next rev.
Old Aug 8, 2005 | 12:56 PM
Morgan's Avatar
Lounge Sweetheart
i think the latest one i have is the N flash...idk...i'm happy with it..you can def. feel a difference...i'm hopeing i won't have to get any other ones. lol
Old Aug 8, 2005 | 02:34 PM
wedge357's Avatar
ShinkaMan #748 SV6P
valpac, the car's ECU already have a programmed "idle cutoff" albeit at a higher RPM than what the R flash will do, so the flash is not "taking over idle control" as you said because it already does.
Old Aug 8, 2005 | 03:28 PM
valpac's Avatar
Ahead of its time
ok, tightening the CONTROL it already has..
EDIT: post #600
Old Aug 9, 2005 | 01:51 PM
Spyder_doo's Avatar
Turbo'd 5
I just got my turbo'd 8 from the dealer with the heat shields installed and the 'R' flash. I dont know of many other turbos that have done this and my car seems to be running better but I'm not wanting to jinx it or anything so I'll give everyone my thoughts on it after a while of driving it. I have the 'M' on it before that so this is a big jump in flashes for me. Everyone plz pray that this doesnt make my car start running like crap or something. I had a CEL come on after driving it for about 5 mins but it went off and I havent seen another one yet.
Jamie
Old Aug 9, 2005 | 07:39 PM
Spyder_doo's Avatar
Turbo'd 5
Ok everyone I need help. My car is throwing a CEL constantly now. It didnt do it before I got the service done and now it's always on. Please help me. Can anyone backdate my flash?
Jamie
Old Aug 9, 2005 | 08:04 PM
Marietta 8's Avatar
Hey Jamie,
backdating can be done but it is not easy and you would be hard pressed to get a dealer to do it for you not because of the turbo but because of what is involved with the wds.
Is it solid on or flashing?
Old Aug 9, 2005 | 10:39 PM
Spyder_doo's Avatar
Turbo'd 5
It's a solid CEL. I dont know what could be causing it. Everything looks like it's the same as when I took it in, but it is running a little wierd now. It wont stay idle everyone and then, plus when it does it idles at about 250. I was thinking that you might be able to do it but I wasnt sure. If I bring it to Mazcare would you be able to look at it and help me try to get it running right? I dont like my dealer, I didnt really want them touching my car but this recall thing started getting me worried so I wanted the heat shields but not the flash but they wouldnt let me not get it.
Jamie
Old Aug 10, 2005 | 12:55 PM
KYLiquid's Avatar
Oil Injection
i called cory fairbanks down here in orlando and told them i wanted to bring the car in for the recal, to check to make sure i have the current flash, and fix my center consol lid. they said no problem, going in this sat.
most of the heat sheild/gas tank recall is just an inspection, they said as long as there is nothing that needs to be replaced they would have the car back to me later the same day. If anything did need to be replaced I could get a loaner car or take the car home and bring it back when the parts are in.
this really suprised me as the dealer usualy sucks at customer service.
Old Sep 1, 2005 | 02:27 PM
Spyder_doo's Avatar
Turbo'd 5
Well just for an update: my car is running more smoother and there's less heat issues thanks to the layers of materials around all the exhaust, they even put an extra one in around the area that the turbo is in. I was having really bad problems there for a while but now I've came to the conclusion that it wasnt so much the flash as it was the CAT that I had put on my car to run the turbo. I'm once again catless and loving the sound once again. For the ones of yall that heard it before I got the turbo, it's nowhere near that loud now. I really like the overall sound it has. Plus the flames it shot every now and then are on demand now. I think it's from running dog rich with the emanage but I hope to tune that out asap.
Jamie
Old Sep 1, 2005 | 02:33 PM
cgrx's Avatar
DRIVEN
called my dealer just now. Bringing it in ASAP and get the MAZDASPEED Miata as a loaner. SWEET
I have no letter
Old Sep 1, 2005 | 03:59 PM
ltorres23's Avatar
Mazdaspeed Enthusiast
Mine was done in about 2 hours. But because I got a Cadillac as a loaner (Enterprise took so looonnnggg to give me a car, I got the upgrade :D ) , I picked up my rx-8 next day morning. They got me a loaner, so I could go to work... @ Cory Fairbanks...until now they have treating me very well, hopefully stays this way...
Old Sep 1, 2005 | 04:03 PM
cgrx's Avatar
DRIVEN
damn, only two hours. I was hoping for longer. Maybe I can drag it out
Old Sep 2, 2005 | 10:03 AM
Spyder_doo's Avatar
Turbo'd 5
Mine didnt take anytime at all. couple hours at most.
theblinkof
Oct 4, 2023 05:24 PM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
