MW RX-8 Forum Serving KY, IN, IL, MO, MI, WI, IA, MN, ND, SD, NE, KS,
Blended Fuel MN vs Iowa?
Old Aug 1, 2005 | 03:04 PM
fray's Avatar
Yesterday I took a drive down to Des Moines.. got <18 MPG on the way down and >22 MPG on the way home!
The only difference as far as I can tell was the fuel. I believe in MN, we use a blended fuel of Ethanol. Does Iowa?
Speaking of which, does anyone know if you can buy non-blended fuel in MN?
Old Aug 1, 2005 | 09:53 PM
Speedrx8er's Avatar
interesting. Could it be the way you drove??
Old Aug 2, 2005 | 07:56 AM
fray's Avatar
On the way down I was at about 4k RPM in 6th most of the way.. (with the occasional down shift/sprint)
On the way back I screwed up for about 20 miles and was sitting at about 5k in 5th.. then went back to 4k in 6th. (And I umm.. was a bit more spirited at times on the way back)..
It's possible it was my driving, or driving condition changes.. but 4+ MPG seems more to do with the fuel to me. I remember reading other reports here that ethanol fuel got worse milage for others.. so I'm curious if the same happened here.
Old Aug 2, 2005 | 07:58 AM
fray's Avatar
Just found this:
http://www.mda.state.mn.us/ethanol/about.htm
It appears that yes, Ethanol blend is required in MN.. Hmm..
cliffkemp
Dec 24, 2024 10:48 AM
Hunterkelley24
Jun 14, 2022 08:32 AM
urbanvoodoo
Sep 30, 2015 12:41 AM
RotaryMachineRx
Sep 29, 2015 10:26 PM
DeltaJ802
Sep 29, 2015 01:20 PM
