Something Strange...
Old Jul 20, 2005 | 11:17 PM
LoveMy8's Avatar
Hey all, this has probably been talked about, but I am going to post anyway. So the other night I am sitting at a red light in neutral and my foot off the brake and gas. All of a sudden, the cars idle drops really low and then the car revs itself up to 1.5k. The engine was warm and whatnot but this was strange. I thought the car was going to stall, but then I guess caught itself. Ever since then the idle has been worst. Can't be any gas, I have used the same gas and octane rating since day 1 and the car has 9,XXX on it now. Anybody have a clue?
Thanx in advance.
-Rich
Old Jul 20, 2005 | 11:50 PM
RotaryNoob's Avatar
Hi
It happens every once in a while with mine. Mainly when its warm out.
Old Jul 20, 2005 | 11:54 PM
tiggerlee's Avatar
May Cause Anal Leakage
same here I noticed it more lately. And it has been fairly warm when I notice it. I've always used 93 octane since I bought it and my driving habits haven't changed.
Old Jul 21, 2005 | 12:42 AM
Ole Spiff's Avatar
Is your A/C on? It will do that sometimes when the compressor is engaged/disengaged.
Old Jul 21, 2005 | 10:13 AM
there is a micro switch that tells the pcm that you have shifted into neutral. if it sticks the pcm can be a little "confused" about what it should have the engine do. hence the strage jumpy idle. happens too often they will replace the switch
Old Jul 21, 2005 | 10:18 AM
wedge357's Avatar
ShinkaMan #748 SV6P
Will resetting the PCM return idle values to default? It might work...
stricek
Jul 3, 2012 06:24 AM
Donald.Clabaugh
Oct 8, 2011 06:40 PM
Alexb
Feb 4, 2010 08:08 PM
BasenjiGuy
10
Jul 31, 2005 07:45 AM
