Catalytic Converter Max Temp
Old Jul 18, 2005 | 09:08 PM
Kewl's Avatar
Former RX8 Owner.
As part of this latest 'lost power' issue I decided to connect the Harrison scanner and record versus sensors while driving home from work - the hot part of the day. While I have not yet had the loss of power issue with the computer connected I had noticed what I would think is a high catalytic converter temp - as high as 1730 degrees. For a short period of time however. Mid 1600's isn't unusual however.
I did a considerable amount of 'searching' on this forum and I see several topics that say 1600 seems high, and one that said rotary engines' CAT can go as high as 2000 - which is really a bit much.
Has anyone else connected the scanner and observered CAT temps....and what was the highest seen?
Old Jul 18, 2005 | 09:28 PM
Kewl's Avatar
Former RX8 Owner.
feeling is sluggish...at least for me...and then only for a short period of time. Check this forum for more information
https://www.rx8club.com/series-i-trouble-shooting-95/power-loss-then-died-62339/
Old Jul 20, 2005 | 06:03 PM
olddragger's Avatar
Last year (and in talking with Canzoomer then) the high temp in the cat was discussed. This subject came up because they where looking into going to a high flow cat. At that time the high flow cats out there could not be mounted because they could not tolerate a 1600-1700 degree temp. They where designed for piston engines and their 1200 degress. So the knowledge that the cat is reaching 1700 is not new. However, I have never heard anyone going over 1700 either. Just for your info .
Olddragger
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
PTQLam
May 23, 2016 11:17 AM
RX-8 Racing
20
May 14, 2016 06:25 PM
Learners_Permit
Sep 27, 2015 07:38 PM
