what's a good aftermarket sparkplug?
Old Jul 11, 2005 | 12:44 PM
projectcar's Avatar
what is a better aftermarket spark plug that will work properly for the rotary engine? im looking for better preformance/...
Old Jul 11, 2005 | 01:35 PM
brillo's Avatar
Go Texas Longhorns!
as far as I know, NGK are the only game in town. Most folks don't use other ones, as they don't seem to work as well. Just replace the stock ones every 30K and you'll be in good shape.
Old Jul 11, 2005 | 02:48 PM
dwill9578's Avatar
yup stockers are the best for now
Old Jul 11, 2005 | 03:08 PM
ZoomZoomH's Avatar
Mulligan User
at $130 for a set the OEM ones better be the best there is!
Old Jul 11, 2005 | 04:29 PM
Fanman's Avatar
Sparkplugs won't do anything for your performance. You don't need anything other than stock unless you have a turbo. I had the colder NGK's (leading), now I have the Denso Iridiums (both leading & trailing are one heat range colder).
there are aftermarket alternatives, but they are a colder heat range designed for continuous high rpm operation, they'll foul for street use
otherwise there's no performance gains to be had from a sparkplug change on a street use RX-8
you can find the OE plugs much cheaper from several online auto parts stores rather than the dealerships (even the discount dealerships)
Old Jul 11, 2005 | 05:44 PM
Xyntax's Avatar
THREAD KILLER
I've only heard about NGKs. As far as upgrading your plugs, mine have been replaced per TSB by warranty for my misfire last month. I've always gotten 15 - 16 mpg for city driving, but after the hotter plugs, I've been consistently getting 18 mpg. Also, the acceleration is smoother and feels faster.
I'm going to dyno this thing again before Summer's end. I've installed REVi with the hotter plugs since my last dyno in Ferbruary.
Old Jul 11, 2005 | 07:10 PM
projectcar's Avatar
ic
i do have the turbo, i was goin to get the stock one's, i was just wondering of any better alternatives tho
Old Jul 12, 2005 | 12:13 AM
Fanman's Avatar
Canzoomer sells the leading plugs one heat range colder. If you have a turbo that might be good for you to look at. I have the Denso Iridiums with both the leading & trailing one heat range colder.
Old Jul 12, 2005 | 03:23 PM
page down for the "new" RX-8 listing, not recommended them on the street!!!
http://www.globaldenso.com/PLUG/racing/spec.html
Old Jul 12, 2005 | 04:24 PM
beachdog's Avatar
www.sparkplugs.com has both the oem ngk's and the denso's.
Old Jul 12, 2005 | 04:49 PM
yeah, it's been covered ad nauseum, Search is your friend
drebbrnator
Dec 27, 2018 07:02 PM
Kahl
Aug 20, 2015 11:49 PM
TheWhiteAce
Aug 6, 2015 02:26 PM
MolecularConcept
Aug 5, 2015 04:43 PM
cushing75
Jul 30, 2015 12:21 PM
