Drill Firewall HELP! Please :D
Old May 21, 2005 | 06:52 PM
truemagellen's Avatar
Attracts tree branches
Exclamation Drill Firewall HELP! Please :D
I am running two 4 gauge wires to the trunk...I've plotted the path and the best way (as other have mentioned) is thru the firewall on the passengers side under the glove compartment.
the big question is where is the best spot?
there is a bolt/nut under the glove compartment against the firewall....is that the same bolt/nut that connects under the window washer fluid tank?
if so, then based on that point how far to the right and up/down should I drill?
also how thick is the firewall?
THANK YOU!!!
(the DIY on this is missing all the pics....so I am running blind on this)
Old May 21, 2005 | 07:29 PM
Old May 21, 2005 | 07:40 PM
Napboy's Avatar
Sho'Nuff
why are you drilling through the firewall when you can run the wires through the rubber grommet on driver side? i know i've seen the diy for the glove compartment drilling behind the washer fluid tank, but i never understood why.
Old May 21, 2005 | 08:18 PM
two 4 gauge wires is why....both over 1/2 size
I've seen the rubber ont he drivers side...way to small...plus many more electronics are run that way....and battery is on drivers side...shortest ground is the best ground
Old May 21, 2005 | 08:24 PM
StealthTL's Avatar
Don't....
Don't drill!
If you take out the washer bottle, there are two grometts, one is huge - it's where the JDM steering column goes! Even the small one is big enough for your wires.
S
Old May 21, 2005 | 08:25 PM
thanks stealth!
this deserves a double thank you!
Old May 21, 2005 | 08:50 PM
adrian-1's Avatar
Ex- member.
Picture of my 4gauge wire. Hole above that is for my greddy harness plus other senors for my guages.
Attached Thumbnails Drill Firewall HELP! Please :D-img_1519.jpg
Old May 21, 2005 | 08:54 PM
Kel Rx8's Avatar
if your not 1st your last
a triple thankyou as im planing on running my amp this week
washer fluid tank is gone...ok there are no rubber gromets on mine
so I'm drilling it seems
Old May 21, 2005 | 08:55 PM
btw ground return through chassis ground is miserable...run a direct ground return to the battery...a seperate one
Old May 21, 2005 | 09:05 PM
what is behind here?????
Old May 21, 2005 | 09:17 PM
adrian-1's Avatar
Ex- member.
You've got a good 2 inches of free space behind the hole to work with. You'll see some sound insulation stuff when you drill through.
Get a clothes hanger and run it down the hole, feel inside on the passenger side, cut a slit in the rubber wall. Tape the wire to the other end of the hanger, run it through. I routed mine underneath the center console to the trunk.
Old May 21, 2005 | 09:20 PM
thank you adrian....I'm going to drill right now :D
Old May 21, 2005 | 10:10 PM
holes drilled :D that was a piece of cake...well kind of :p
the largest drill bit I could find was 1/2...that is fine for cramming the wire in there but I have some nice hard plastic firewall passthrough grommets that are slighly bigger with a diamter designed just for 4 gauge wire...so I had to dremel the hole bigger
unfortunately one of the holes I began to drill was causing trouble so I have 3 holes :o 2 almost perfect ones and 1 funny one...I'll jam a rubber stopper in there for now...but it should be ok since it is about 5/6 gauge in size and behind the washer fluid tank
thanks everyone for you help!!!!!!!!!!!!
Old May 21, 2005 | 10:39 PM
StealthTL's Avatar
Heater....
....on US cars, these grommets house the heater and a/c lines, and they ALL fit thru one hole!
It should be hard to miss?
S
Old May 21, 2005 | 11:40 PM
I see the gromit you speak of but it is not suitable for running 4 gauge...right now I've got the wiring through the holes I drilled...the fuse holder is mounted...I'm now attaching the postive...and soon the negative...I actually decided to cut a hole in the battery cover
then I'll run it along the side of the car under the interior scuff plates...under the rear passenger seat and into the trunk :D
my back hurts
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
WingleBeast
Sep 9, 2015 10:10 AM
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
