What tire pressure?
Old Apr 29, 2005 | 06:52 PM
weekendwrench's Avatar
What tire pressure?
What tire pressure should I run? I have the stock 18" rims and tires. I drive mostly around town. I noticed the manual says 32 lbs. Any other suggestions?
Old Apr 29, 2005 | 09:05 PM
MadDashRX8's Avatar
Resu Deretsiger
Out of curiosity, I bumped them all up to 36. Ride smoothed out a bit (can't hear or feel all the tiny cracks in the asphalt as much anymore). Handling felt a little different also, but cannot describe in words how it changes. Good or bad, dunno. Still daydreaming about new wheels and tires anyways, so not too concerned with premature wear and tear.
Any other takers?
Old Apr 29, 2005 | 10:48 PM
Urchin's Avatar
I do 35 lbs on all four. Generally do that on all our cars.
Old May 3, 2005 | 05:08 PM
Raz0rama's Avatar
I am the God of Hellfire!
as long as you're under 50psi your fine (max load according to sidewall of tire is 51psi) I find that between 40 and 45 is comfortable and least road noise/ doesn't trip the tpms either so its fine.
Old May 3, 2005 | 05:09 PM
Im_DANomite's Avatar
I love GOOOLD
40 and 45?? wow...that's really high.
Old May 3, 2005 | 05:13 PM
midlife crisis's Avatar
I had bumped the stock Bridgstones up to 35 and I thought it plowed in corners or was this only the fact it was under 40 F??
Old May 3, 2005 | 06:11 PM
tuj's Avatar
tuj
Best handling I got (for autox) was at 40 all-around cold. Heated up to 47 front, rear stayed around 42. At those pressures on the stock tires, the suspension seems to use the front tires more effectively, making the car much more neutral. (Note I also have rb front bar and autox alignment).
Old May 4, 2005 | 12:03 AM
slllygrl10's Avatar
EX-Member
I have 19's and I put 38-39 all around staggered wheels.
Old May 4, 2005 | 12:11 AM
RX8-CARL's Avatar
Over or under inflated tyres just cause extra wear.
32 psi should be fine, a few psi + or - should be OK.
Old May 4, 2005 | 11:31 AM
Kel Rx8's Avatar
if your not 1st your last
32psi F-
36psi R- in stagged wheels
stockers @ 35psi all around
Old May 4, 2005 | 08:58 PM
salituro64's Avatar
Stock 32PSI
cliffkemp
Dec 24, 2024 10:48 AM
hufflepuff
May 30, 2016 10:45 AM
snowrydr01
Nov 23, 2015 09:40 AM
