voltage issue
Old Apr 4, 2005 | 05:16 AM
skc's Avatar
skc
rev it up
voltage issue
The other day I was griving at night and had to pull over to read the map just to get my bearings.
I noticed the room light dimming and getting bright in synchrony with the the indicator. I found this very unusual and have never encountered this in any other car before.
I also have noticed that the charge light in my mobile phone to be a lot dimmer copmared to when it is plugged into my other car...Mazda 626
Has anyone else noticed this.
skc
Old Apr 4, 2005 | 07:15 AM
Gomez's Avatar
Shifty Bastard.
This is what's going on. It's all AOK, BTW. You were pulled over and idling with your headlights on (maybe A/C too?) high beam maybe? The alternator is rated at 100A....but that would be at some RPM above idle. At idle with the lights on, the current draw on the battery that night was more than the alternator could supply to maintain a steady battery voltage. Hence the flickering interior lights each time you asked for more current (ie, when the three indicators lights blinked on). If you'd revved it a bit, she would've all been all hunky dory .
Gomez.
Old Apr 4, 2005 | 05:09 PM
Gibbo's Avatar
In between cars, RX8-less
No No No.......tht is not right at all....
The hampster in the wheel is having heart failure. It's called a rotory because of the hampster wheel.
Anyway you hampster is dying, duck down the local pet store and get a new one before you have a total engine failure on your hands.
Old Apr 4, 2005 | 07:26 PM
timbo's Avatar
rock-->o<--hard place
Help! what sorta hamster food should I use? :p
Old Apr 4, 2005 | 09:36 PM
mikeyr's Avatar
i need a new photo
Tried upgrading my hamster to a rabbit, but it's bloody ears kept getting caught in the wheel!
Old Apr 4, 2005 | 10:24 PM
skc's Avatar
skc
rev it up
So you guys are trying to take the mickey (mouse) out of me eh. :p
Well it aint gonna happen
skc
Old Apr 5, 2005 | 12:05 AM
timbo's Avatar
c'mon mikey...it clearly says in the manual "if upgrading hamster to rabbit, please be sure to remove rabbit ears first" ... and of course later on (though often missed) "removed rabbit ears may used a tv aerial" .... boom boom :o :o
Old Apr 5, 2005 | 01:00 AM
mikeyr's Avatar
i need a new photo
Timbo, I started reading the manual and when it got to "first remove gaffa tape...." i stopped cause i came over all shy......:o
Brettus
46
Apr 19, 2024 06:28 AM
stickmantijuana
Non-Rotary Swaps
Sep 19, 2015 03:15 PM
tgaffner
Sep 7, 2015 08:49 PM
