Front-light washers
Old Jun 16, 2003 | 02:35 AM
rael's Avatar
Front-light washers
The great new pictures posted (in superb resolution) show a rectangle mound under front-lights. Are the washers hidden under that?
If so the TT has a similar contraption out of which the washers poke forced out by water pressure (the washers strange appearance has resulted in them being called the 'aliens') and the retract again. The driver can never actually see them appear unless somebody else is working the controls.
rael
Old Jun 16, 2003 | 02:42 AM
c170673's Avatar
www.rx8ownersclub.co.uk
I think that is the case.
The washers are required by law for the Xenon Headlights, so I assume the standard power versions will not have them as they are equipped with Halogen headlights.
Chris
Old Jun 16, 2003 | 03:02 AM
AndyPearce's Avatar
Chris
As I know nothing about Xenon headlights could someone please explain why there's a legal requirement for washers?
Old Jun 16, 2003 | 05:12 PM
Stu C's Avatar
Can't Re Member
yeah, I'd like to know why Xenon headlights have to have washers.....
STU
Old Jun 16, 2003 | 06:09 PM
this is just a guess mind you. one of the reasons drivers dislike seeing Xenon's coming at them is the dispersal of light around the edges which causes the "glare" associated with them. one of the ways used to lessen this glare is the autoleveling. perhaps dust and dirt getting on the lenses causes more light dispersion and therefore more "glare". thus having the pissers (as they are known here in the states) wash the dust off lessens the problem.
Old Jun 17, 2003 | 01:05 AM
morganrogers's Avatar
Mucho Senior Member
I think they could find themselves disconnected....
Last thing I want over my freshly and lovingly polished RX8 is 2 streaks of soapy water running back at me up the bonnet ! (hood to some of you)
Old Jun 17, 2003 | 02:44 AM
rael's Avatar
They should only work when the lights are on and then only when the front window washers are used ie they will not mess up your bonnet unless you need to clear your window (in which case presumably you would also need you lights to be cleaned) Mr Rogers.
rael
OnebaddRx8
Aug 25, 2019 11:34 PM
MolsonB
Aug 18, 2015 08:42 PM
akagc
Aug 11, 2015 07:07 PM
KBert
12
Apr 15, 2004 08:43 PM
