eManage support tools re-written, alpha testing anyone?
Old Mar 1, 2005 | 01:31 AM
seikx8's Avatar
Is this title ok?
Just want to shared what I've been working on since I visit this site pretty frequently.
http://12.22.230.41/MicroTech/Host/F...ools.Alpha.zip, this is a rewritten of eManage Support Tools using .NET C#. Currently it only has limitted features: Data logging and save to .csv file, graph A/F ratio value, Auto tune the Airflow map base on a target A/F ratio. Ability to log 2nd AirFlow input & TP Voltage value, this is good alternative for Wideband O2 data logging via the 2nd Airflow input.
Note: Work with firmware 1.39 & 1.42. The Auto tune feature DO NOT work with CANZOOMER box (may be if there are enough interest, I might make it compatible ), since it implemented to take away fuel by a negative value. And Required .NET framework 1.1 to be installed.
Hope this is useful,
Old Mar 1, 2005 | 08:09 AM
Speed Racer's Avatar
Certified track junky!!!
Sounds good! I'll have to check it out this weekend.
mdl0209
May 23, 2019 05:46 PM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
