Smoking
Old Feb 28, 2005 | 12:04 PM
bmcc49er's Avatar
Smoking
This happened after the dealer did the first oil change. He said he didn't get the filter on correctly and spilt oil. After driving the car I would pull into my garage and it would be smoking like crazy, bad oil burn smell. Oil level fine. Now i changed the oil two weekends ago and again its smoking and oil is under the car. No leaks from the pan or bolt and no leaks from the filter. Is it possible to spill that much oil when you take the filter off that it would pool somewhere and slowly leak and burn off? I spilled a little getting the filter of but didn't think it was this much. Last time this went on for about a week and then went away.
Old Feb 28, 2005 | 12:45 PM
RotaryNoob's Avatar
Hi
Double check your filter and oil pan bolt. I've never seen any drip to the ground or smoke from dripping a little out of the filter when you take it off...
Old Feb 28, 2005 | 01:08 PM
bmcc49er's Avatar
I agree, but last time the dealer changed it the exact thing happened. I just checked my oil level and its still good, flashlight to the filter and pan bolt and no leaks. Is it possible I spilled more then I thought and is there somwhere for it to pool and not spill straight out the bottom? The car is running fine it seems but once i shut it off I get the smoking from the hood and the smell.
WranglerFan
May 31, 2022 07:51 AM
Luiss7
54
Aug 20, 2019 08:56 AM
WranglerFan
Nov 5, 2017 09:35 AM
pjwermuth
Sep 28, 2015 11:36 PM
Rx8_412
Sep 24, 2015 08:51 PM
