Anyone know of 200+whp STOCK RX8s? I saw one today...
Old 02-26-2005, 05:16 PM
dmp
RX8 and a Truk....
dmp's Avatar
206hp...yup. Saw it...it's on film
Today a few NW RX8 ppl gathered for a dyno. MOST RX8s there spun about 185 at the wheels...very consistantly within a couple-few HP of one-another.
Until the Silver w/ Red/black leather went...198whp on one run...he hit 206 on another...His A/F ratios were in the mid 12:1 range; compared to my cars A/F's were were a solid point richer.
I'm not going to steal his thunder furhter, so I'll let him post up about it...
Thanks to all who posted up - I'll get pics/vids up before the weekend is over.
:D
Old 02-26-2005, 05:18 PM
Custom User Title:
No More Oldsmobiles's Avatar
Uh-oh. More hp and it's silver.
Old 02-26-2005, 05:34 PM
"Call me Darkman"
DARKMAZ8's Avatar
details pleez!!!!!!
Old 02-26-2005, 05:40 PM
Attracts tree branches
truemagellen's Avatar
variation is common...thus tuning can really make a difference with no additional mods
Old 02-26-2005, 05:42 PM
haha!
Old 02-26-2005, 05:49 PM
dmp
RX8 and a Truk....
dmp's Avatar
The car is just a stock rx8 with 14K miles. nobody is sure why, but his car stays nice and (safely) lean...unlike ours which dip into 'pig rich' conditions.
When we get $, we're thinking about swapping his MAF/ECU into another car to see if those could be causes.
Old 02-26-2005, 05:55 PM
Ike
Blue By You
Ike's Avatar
What flash is he on compared to you?
Old 02-26-2005, 06:15 PM
Same flash as far as we can tell. It was quite a day. I have all the data on a CD...so when I get it organized I can send it to everyone concerned if they want it.
I have a problem with my car....for whatever reason it would max out at 130+/-. Ran it twice, six or seven runs each...with new gas in between...checked the plugs. It has run OK til this AM...and it crapped out on the way to Kirkland to the dyno ....after a fill up at a Chevron??
I ran it down to 1/4 tank...refiled, and dyno'd again...same thing
Anyone have any ideas......I also ran it with CZ on, off, out, reset. doesn't seem to be the piggyback it altered the A/F as expected, just no power. Coilpack??......By the way... the guys at Carbconn were great! www.carbconn.com. I guess I'll have to take it in with the dyno graphs ( the stock ones :D) and get them to take a look
Old 02-27-2005, 12:18 AM
THREAD KILLER
Xyntax's Avatar
Cool! You guys had 8s running dyno too! Four of us did ours here in San Jose. Check out our results at the West Forum.
Old 02-27-2005, 12:24 AM
Boost needed
IZoomZoomI's Avatar
dam 206 stock... where is this guy!? That's what rx8 should be. Wonder what mazda did right with his car.
Old 02-27-2005, 12:43 AM
THREAD KILLER
Xyntax's Avatar
^ Probably screwed the ABS interference in the ECU thus freeing his RX-8 to run the way it should on a dyno :D
Old 02-27-2005, 12:44 AM
Bigus Rotus
Nemesis8's Avatar
How about a teaser vid of our day. This was the highlight of our day. Click on the teaser.wmv file. It's 3186KB
http://www.hausers.com/nemesis8/videos/
DMP is going to host more vids once we get them rendered.
Old 02-27-2005, 12:48 AM
Reactionary's Avatar
Finally, we got the counterexample. All us owners are going to owe you big time. How are you dynoing the cars? Everything Canzoomer said to do? Avoided limp mode?
Old 02-27-2005, 12:51 AM
Boost needed
IZoomZoomI's Avatar
straight through aye? who's car was this?
Old 02-27-2005, 12:53 AM
Bigus Rotus
Nemesis8's Avatar
Dynojet
DSC/TCS Disabled
5th Gear Pull
Wheel sensors left on the car untouched
Old 02-27-2005, 12:57 AM
Bigus Rotus
Nemesis8's Avatar
That was a "Fastmike" mod to see what it would do. I missed the second pull flame. It shot out three feet! That was the third pull flame.
Old 02-27-2005, 01:00 AM
Ajax's Avatar
Were all of the dynos run in 5th?
Old 02-27-2005, 01:02 AM
Fanman's Avatar
So Nemesis, how much did you pull ? Was over at the So. Cal. meet met a few RX8 club members, had a good time.
Old 02-27-2005, 01:04 AM
jenkins-crew's Avatar
maybe I missed it but what year was his 8?
Old 02-27-2005, 02:58 AM
MazdaManiac's Avatar
Myth. ABS (more accurately - TCS/DSC) does not interfere with dyno runs on this car.
There is no "limp mode" - at least not for these reasons. It is documented in datalogs while on the dyno. The ECU does nothing to pull power just because the wheels aren't spinning the way it wants to.
The ECU can affect power three ways - through fuel deliver, ignition timing and throttle position. It changes none of these while on the dyno.
Old 02-27-2005, 03:21 AM
Boost needed
IZoomZoomI's Avatar
my abs light did turn on after the dyno run, so did one other owner. Can you explain this?
Old 02-27-2005, 08:29 AM
Yes. Your ABS system didn't like seeing some of the wheels spinning and others not. This has been the case with ABS systems for decades.
However, it does not cause the PCM to pull power as others have claimed (provided your TCS is off).
Old 02-27-2005, 08:36 AM
DRIVEN
cgrx's Avatar
why the loss from the flywheel?
It should be less than average with eletric steering/carbon fiber drive shaft, etc.
Old 02-27-2005, 09:41 AM
Bigus Rotus
Nemesis8's Avatar
Here are my pulls attached. The site conditions were: 59.86 Degrees F, 29.94 in-hg, humidity 45%, SAE: 0.96
Attached Thumbnails Anyone know of 200+whp STOCK RX8s? I saw one today...-uncorrected.jpg   Anyone know of 200+whp STOCK RX8s? I saw one today...-corrected.jpg   Anyone know of 200+whp STOCK RX8s? I saw one today...-air-fuel.jpg
Old 02-27-2005, 11:32 AM
dmp
RX8 and a Truk....
dmp's Avatar
One oddity I noticed yesterday...
All/most of us dyno'd about mid-140s lbs-ft of torque...that's about a 10% loss from the factory rating of ~160....I wonder why the car appears to lose much less tq thru the drivetrain as it does HP.
Quick Reply: Anyone know of 200+whp STOCK RX8s? I saw one today...
