HID Conversion Question
Old Feb 20, 2005 | 12:00 PM
Ktreece777's Avatar
What all is needed to convert the base model headlight package to HID as far as OEM? Does anyone know what this usually runs?
Old Feb 20, 2005 | 08:11 PM
Silverarrow's Avatar
OldeSpeede, Inc.
I too am interested in this, so far the only answers i have seen are "too much" so no one seems to have numbers for it. ANYONE?
Old Mar 2, 2005 | 10:02 PM
Ktreece777's Avatar
Old Mar 2, 2005 | 10:19 PM
snap-on's Avatar
The HID module is entirely different than the standard set up
Along with the different bulb/25kv bulb module (all self contained) you have to address the alignment sensors on the front and rear control arms.
Old Mar 3, 2005 | 09:40 AM
rx8wannahave's Avatar
Follower of CHRIST!!!!!!!
From what I have read...it's alot of work and it might not be worth it based on the person.
I have the base 6spd RX8 too and but I think my lights are GREAT! I might change them out to get more WHITE light but other than that I wont be messing with it.
What I really wanted was the fog lights....I might add those later on.
Old Mar 4, 2005 | 12:49 PM
TxRx8's Avatar
Bipolar Member
I got an aftermarket HID system and it wasn't hard to install at all. Given you have to take off your front bumber and remove your headlights. It's really easy. I mounted the Ballasts right above the oil-coolers. Then I put the igniters in the engine bay zip tied to the stock wires. All in all they look great. The whole thing took about two hours. And like I said in my other thread, most of the time I spent looking where to mount the ballasts. As a matter of fact I think I have a pic I took a while back with my phone. I'll check and post it here.
*edit*
Here's where I mounted the ballast. It's Zipped tied on right above the oil coolers.
Old Mar 4, 2005 | 12:52 PM
TxRx8's Avatar
Bipolar Member
Originally Posted by djseto
I have yet to see a readl HID system for less than a $1000+. You get bulbs that mimic HID output, but unless you wanna spend way too much money, you will never get true HID
This is not true. I spent $300 and got a quality stage 2 HID system from McCulloch.
Old Mar 4, 2005 | 06:36 PM
snap-on's Avatar
I think the intent was to get it set up the same as OEM.
Many of Mazda6 owners have converted the standards to aftermarket as they are not available on the US built models.
Old Mar 4, 2005 | 07:21 PM
G8rboy's Avatar
Mmmmm... Rotary Donut
$300 for an full HID kit? I love to see how long that lasts. I know a some of the cheap kits ($500-$600) are not DOT certified... I'd be amazed if that one is.
Old Mar 4, 2005 | 08:36 PM
TxRx8's Avatar
Bipolar Member
Friends of mine that have bought this kit say that it lasts around 2-3 yrs. I hope they're right.
Sorry about not reading the part where you wanted the OEM HID. That will run in the thousand dollar mark easy. With labor and all.
Old Mar 4, 2005 | 09:06 PM
Tigster's Avatar
RX8 ADDICTED!!!
I asked Mazmart who is a vendor here about changing the lights out. They were not cheap, and they told me the projector lights use a 4 wire ststem and the hid's use a 8 wire. They also said it would be very difficult to convert to a hid system. I have decided to just buy whiter bulbs and fog lights
Old Mar 4, 2005 | 09:15 PM
slllygrl10's Avatar
EX-Member
I got mine for 360 including shipping a friend installed it for 70!!!!
Old Mar 4, 2005 | 09:33 PM
Kel Rx8's Avatar
if your not 1st your last
check out
proxenon.com ask for mike
Old Mar 4, 2005 | 10:06 PM
TxRx8's Avatar
Bipolar Member
Aftermarket HID's rule. :D
arexatemate
Oct 9, 2015 06:23 PM
Ian_D
Rotary Swaps
Sep 23, 2015 11:22 AM
wayloco
Sep 1, 2015 09:03 PM
