RX8 Self Locks
Old Feb 4, 2005 | 07:15 PM
Earle Gotfrit's Avatar
RX8 Self Locks
Had the car about 6 months and have noticed about two dozen instances of the car locking itself while no one is around. Last time it happened I opened the trunk with the key phob and after closing the trunk (about 20 seconds later) the car locked itself. The phob was sitting on a table at the time - no chance that I had pressed it accidently. Anyone else having the same problem
Old Feb 4, 2005 | 07:23 PM
GRT8's Avatar
I now own a RX8 but I had a Mazda6 before this. If you unlock the door(s) but don't open them in 45 seconds they relock themselves. Did you unlock them at all initially?
Old Feb 4, 2005 | 07:59 PM
you think it locked because the lights flashed yes?
Old Feb 4, 2005 | 08:12 PM
Nemesis8's Avatar
Bigus Rotus
Owner's Manual Page 3-4
30 Seconds
Old Feb 4, 2005 | 08:22 PM
Independent of the lights. The doors are locked
Old Feb 4, 2005 | 08:45 PM
what im saying is that if the doors were already locked and then you pop the trunk the doors STAY locked BUT the alarm is disabled. when you reclose the trunk the alarm re-arms and the lights flash. so i was asking - do you think it locked because the lights flashed or did you hear them lock?
Old Feb 5, 2005 | 05:41 AM
Mikelikes2drive's Avatar
when i open my trunk even with the doors still locked... my alarm does not turn off or at least my shock sensor doesnt go off. Cuz many times has it happened where i dont unlock my car but just open my trunk and take out a jack or sumptin and close the trunk kind of hard and the alarm goes off.
Old Feb 5, 2005 | 07:15 AM
rx8cited's Avatar
Originally Posted by zoom44
what im saying is that if the doors were already locked and then you pop the trunk the doors STAY locked BUT the alarm is disabled. when you reclose the trunk the alarm re-arms and the lights flash. ......
What you talkin' bout'? According the my experience, what Mikelikes2drive says, and the manual:
"The trunk lid can be opened with the key or the transmitter even when the system is armed. The alarm will not come on and the system will remain armed."
So there should be no flashing when the trunk is unlocked/locked.
Old Feb 5, 2005 | 07:28 AM
rx8cited's Avatar
Yep, this would explain it. I unlocked my doors with the FOB, then without opening any doors, FOB the trunk open, then closed it ......... 30 seconds later the doors locked and lights flashed. If you open a door after unlocking the car, self locking won't happen.
Old Feb 6, 2005 | 05:37 AM
Thanks Nemesis. You had the answer. Don't know why they programmed the car to do this, however at least I now know why it happens.
Old Feb 8, 2005 | 06:56 AM
Zorro's Avatar
the car is meant to do that
Old Feb 8, 2005 | 08:11 AM
Paul_in_DC's Avatar
Rotary Public
Also note that if you lock using the key fob, and the lights DON'T flash, you need to check. I did that once, then discovered my trunk lid wasn't completely closed. I closed the trunk lid and then the lights flashed.
Old Feb 8, 2005 | 10:18 AM
i have no idea what i was saying. sorry guys brain fart. it happens sometimes
Old Feb 8, 2005 | 12:04 PM
rx8cited's Avatar
It's okay . It happens to the best of us.
Crazy.8
Apr 18, 2017 03:17 PM
RXeckless
Aug 16, 2015 12:51 PM
Jmanie9515
Jul 20, 2015 07:29 PM
AussieGray
Jul 16, 2015 03:58 AM
