race tranny or built tranny
Old Jan 20, 2005 | 02:59 PM
intakedrotary's Avatar
does anyone know of a website or place that can build up my tranny or have tranny's for rx8's that can handle more than our normal power? I'm building my motor completely with mazdatrix parts and need to obviously beef up my tranny. I have the greddy turbo kit going in with the nitrous expresss intercooler spray kit and having it tuned and everything for 8 psi on one setting and 12 psi on the other, but in the long run, i'll run closer to 15 with everything built.
Old Jan 20, 2005 | 03:32 PM
easymmkayrx8's Avatar
why not take the stock transmission as far as it can go? Mazda puts out awesome transmissions, if it's even close to the quality they put out with the rx7 transmissions you should be fine with that setup.
Old Jan 20, 2005 | 06:37 PM
Virgil's Avatar
You should be good if your clutch and and flywheel are replaced with stronger ones, it seems most of the problems come from botht he clutch and the flywheel getting chewed up or at least thats the re accuring problem that I see people talking about.
Also, got to say that your 8 sounds ******* sweet from the description in your Sig, much of what I want to do although I would have gone with some better cooling elements such as an better oil cooler and radiator (Mazdaspeed racinging selles a kit with a sports radiator and an oil cooler and a couple other things to make it race ready and a factory bolt in roll cage, something I am very interested in.
Old Jan 21, 2005 | 02:02 AM
thanks
thanks for the advice and support. I am once spring comes around, installing a PWR Radiator, since it's winter i'm not too worried right now.
Old Jan 21, 2005 | 02:36 AM
Aoshi Shinomori's Avatar
Kaiten Kenbu Rokuren
Has anyone gone in and gotten their gears shot peened?
Old Jan 24, 2005 | 09:27 AM
Virgil's Avatar
Oh, hey, it seems ATS produces a Carbon Clutch for the RX-8.
www.a-t-s-usa.com
I will check it out and give you some feedback form what I find.
Old Jan 24, 2005 | 10:26 AM
ssspeedfreak's Avatar
I am also looking for a clutch and flywheel replacement. Mine never last long because i am always racing. If you find some better info. on these let me know i would love to have a clutch last the life of my car. Hay if porsche could do it in the GT then i want to do it in my 8.
theblinkof
Oct 4, 2023 05:24 PM
Hunterkelley24
Jun 14, 2022 08:32 AM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
RAVSPEC
Vendor Classifieds
Oct 1, 2015 01:59 PM
