WOW something i didnt know about the 8
Old Nov 5, 2004 | 04:04 PM
Like Whoa's Avatar
OK so I'm listening to my new Eminem CD and i noticed that i needed to get gas, so i pull in to the nearest gas station and i tell them to fill it up and wutever. i turn off the car but not all the way, i left my radio on. i'm listening to the cd and a couple of minutes the interior lights flashes/pulsates with the beat of the music. Thats insane!
did you guys know this or am i the guy thats a little slow?
Old Nov 5, 2004 | 04:08 PM
Nemesis8's Avatar
Bigus Rotus
What? to the beat of the music? Are you serious?
Old Nov 5, 2004 | 04:16 PM
BasenjiGuy's Avatar
The pulsating lights would be would be due the battery draining....
since
Old Nov 5, 2004 | 04:21 PM
Tony Orlando's Avatar
Bored thread resuscitator
Yeah, I was thinking the same thing....
Old Nov 5, 2004 | 04:47 PM
Ike's Avatar
Ike
Blue By You
The surge from the bass was just causing the lights to dim most likely, you may want to get your battery checked...
Old Nov 5, 2004 | 04:51 PM
VelociRedBeast's Avatar
.....It Would be cool though..
Old Nov 5, 2004 | 05:14 PM
StewC625's Avatar
Insanely Yellow
yup, that's battery draw ...
Old Nov 5, 2004 | 05:29 PM
slllygrl10's Avatar
EX-Member
Lol
Old Nov 5, 2004 | 06:02 PM
bxb40's Avatar
Rotary Newbie
Might want to check the alternator as well, a battery should not drain so fast... 5 min while getting a tank of gas...
Old Nov 5, 2004 | 06:40 PM
truemagellen's Avatar
Attracts tree branches
Originally Posted by abbid
i do that all the time, and my lights have never flashed. once i drove around for about 20 minutes with only the parking lights on, and when i turned the car off, the radio was still goin. i thought it was broken until i turned the parking lights off. Havent been able to replicate since.
I have...it is simple...if you put something into the lighter outlet with reversed polarity (ie ground is not hooked to ground) it will lock the radio/interior lights/navigation/outlets everything ON!
it will run till you remove the device from the outlet for 1 second or more...seriously I turned off the car, removed the keys, closed and locked the door everything was still running!!!!!!
the way I found out is a crappy dvd player I hooked up to the av box for video into the nav...and I couldn't turn anything off...it freaked me out for a while then I remembered something about grounds and complex electrical systems and I pulled out the plug
Old Nov 5, 2004 | 06:41 PM
oh and how loud did you have it? any extra amps installed?
Old Nov 5, 2004 | 07:18 PM
wokuku's Avatar
Did u know that you can open/close the windows after you turned off the car. The switches continue to functions until you open the door~
Old Nov 5, 2004 | 07:28 PM
yup but it will only work for a minute or too...too bad the stereo doesn't keep playing too until the door opens like some dodge and ford suv/vans
Old Nov 5, 2004 | 08:26 PM
xdrian's Avatar
Banana Yellow :P
I've tried it but it hasnt happened to me. And i just found out before that i can open my window when I turn of my car and take the key out :D
Old Nov 5, 2004 | 08:39 PM
galleychief's Avatar
Unbalanced & Unmedicated
Perhaps the car has an inherent dislike of Eminem and was discharging the battery on its own to stop the noise. . . :D
Old Nov 5, 2004 | 08:40 PM
Gomez's Avatar
Shifty Bastard.
The door wasn't fully closed and the bass was rocking the door on the interior light switch on the forward edge of the rear door. Battery is okay....
Old Nov 5, 2004 | 08:50 PM
buzzardsluck's Avatar
You beat me too it galleychief lol
Old Nov 5, 2004 | 09:02 PM
Like Whoa's Avatar
nah uh, i played the music low and loud. its happened like 4 diffrent occasions. i went to get my rotor resurfaced last week and said my batterys are fine. and nothing installed, everything stock
Old Nov 5, 2004 | 09:23 PM
Gomez's Avatar
Shifty Bastard.
Door switch needs adjustment....lean against them when the door is closed and the lights will come on.
Old Nov 6, 2004 | 12:03 AM
Like Whoa's Avatar
so is this normal? is my 8 the only 8 with pulsating lights that go with the music?
Old Nov 6, 2004 | 09:02 AM
Yes. Consider your 8 unique.
But really, I think GOMEZ was closer to the actual cause. Check your door switch, if that is not it take it to the dealer and demonstrate it to them if you can.
Old Nov 6, 2004 | 02:46 PM
Like Whoa's Avatar
ok i know how to do it now.
first i turn the key all they way without starting it then i put my windows down and then i turn back but not all the way, just enough so that the radio is still on. and then i put up or down the window and then a few seconds later all the lights in the car come on and starts doing that beat
Old Nov 6, 2004 | 03:23 PM
Tayninh's Avatar
I am going with Gomez here. Sounds like the door is not fully closed and the beats makes the lights flash. If that's not it, then you have an interesting car.
xAgyex
Jun 3, 2026 03:47 PM
Audio Concepts ATL
Sep 26, 2021 01:59 PM
8th1der
32
Jul 7, 2006 08:55 AM
