6 disc in dash player sucks, won't load
Old Oct 23, 2004 | 11:12 PM
djgaston's Avatar
I cannot get the in dash cd changer to load more than one CD. I hold down "Load" and nothing ever happens. Am I doing this wrong or what? It doesn't beep or flash anything, it just sits there.
Old Oct 23, 2004 | 11:35 PM
irish8's Avatar
Get in ma belly!!
Take it to your dealer for repair. Has it ever worked?
- Irish
Old Oct 23, 2004 | 11:43 PM
djgaston's Avatar
We just bought the car this past week and it hasn't worked yet. I went to the dealer today and they just told us to keep messing with it. I was hoping it was a common problem or something that I was overlooking. Dammit.
Old Oct 24, 2004 | 12:32 AM
irish8's Avatar
Get in ma belly!!
Originally Posted by djgaston
I went to the dealer today and they just told us to keep messing with it. Dammit.
That's B.S.!! Don't get discouraged. Take it back to your dealer and speak directly to the service Manager. Push for them to replace the headunit. Period.
Good luck.
- Irish
Old Oct 24, 2004 | 04:34 PM
Hammer's Avatar
Go REDSKINS!!!!!
Are you sure you have the 6 disc changer? The load button is on all the cars, wether they have the changer or not. It doesn't do anything that I know of for the single disc headunit.
Does your faceplate say 6 Cd?
Also, your dealer is full of it for telling you to just keep messing with it. That's their job, not yours. You need to let them know that.....they might be putting you off to avoid admitting they didn't actually give you the 6 disc changer, also...
Old Oct 24, 2004 | 05:10 PM
thew's Avatar
Thews8
yes.. i vet you have the single disk ver.. you only need to push it once ans the tray will cycle around till it finds an empty slot the the display will say insert cd.
if yours doen not do this the you have the single disk.. Many dealers say your getting the 6 disc ver.. mine did to.. So look on your window sticker. the car doesnot come withthe 6 disk unit stock.. it has to be added by the dealer. you can tell by looking at the black plastck part over the volume ****. if it only say push Power Vol and Disk then you have the single disk unit.
Old Oct 24, 2004 | 05:18 PM
djgaston's Avatar
Well I'll be... I just looked at the window sticker and no mention of the 6 disc in dash CD player. They swore up and down it had one.
Thanks guys, that solves that problem. You can only listen to one of them at a time anyway so I guess it's not that big of a deal.
Old Oct 24, 2004 | 05:45 PM
thew's Avatar
Thews8
you need to go kick some ***.. they did the same to me.. make them kick in the cash to get a 6 disk unit installed.. And then do the install yourself.. just make them buy the unit.
Old Oct 24, 2004 | 06:08 PM
truemagellen's Avatar
Attracts tree branches
haha same thing happened to me 'its got a six disc changer', yea right! I made them throw in many goodies for their error (since I could care less if I had a six disc changer or not :p )
Old Jul 14, 2012 | 12:15 PM
Regina D. Reviere's Avatar
2004 rx8 cd player stuck, can't remove cds (6 disc player). That seems to drains battery and I have to jump start it. Pls advise
Old Jul 14, 2012 | 12:24 PM
firebirdude's Avatar
User and Abuser
Welcome to the message board. The factory disc changer not ejecting is common. However I really haven't heard of it killing anyone's battery. I would make sure it's the CD player causing your battery drain. Pull the fuse to that circuit and make sure the CD player has no power. See if that stops killing your battery.
Regardless, the CD player is toast. There is no "opening it up and fixing" it. If you can find another player from a scrap yard for under 100 bucks, then it might be an option. Players from Bose vehicles are different than player from non-Bose, so watchout for that. Otherwise, I recommend going aftermarket and buying the Metra kit (details in the FAQ thread at the top).
FubarI33t
Sep 28, 2015 08:45 PM
Learners_Permit
Sep 27, 2015 07:38 PM
drlubell
Sep 26, 2015 11:58 PM
