Spark Plug Gap
Old Sep 13, 2004 | 11:42 PM
HERO's Avatar
Spark Plug Gap
Hey guys, I was wondering what effects would be created by changing the spark plug gap. Leading plug... trailing plug(or whatever they are called)... i'm not too firmiliar with the rotary design . Has anyone tested any different gaps?
Old Sep 14, 2004 | 01:59 AM
ZoomZoomH's Avatar
Mulligan User
can you even gap a rotary engine spark plug??? there's no 'tip' to adjust it... it should come pre-adjusted ready for use...
Old Sep 14, 2004 | 08:00 PM
HERO's Avatar
ah i see, like i said im a rotary noob :o
Old Sep 15, 2004 | 09:08 AM
MyRxBad's Avatar
Fb's rock!
The gap comes preset from NGK. I wouldn't mess with the gap because if you open it up too much you could end up taking out your apex seals.
Old Sep 15, 2004 | 10:18 AM
ZoomZoomH's Avatar
Mulligan User
how do you adjust a spark plug with no tip, like a rotary engine plug???
Old May 11, 2008 | 10:57 PM
AJ's Shinka's Avatar
Enthusiast
Widen the Gap
Umm I just change out my stock with a brand new stock pair of NGK and I widened the gap because the DIY said I could widen it to .059 (leading) and .055 (trailing) I adjusted them to .040 (which was wider than what they came out of the box) but you say they come out the box at .048. I hope I didn't mess anything up.
Old May 12, 2008 | 12:13 AM
Enthusiast
Thanks Ray, I'll go back in tomorrow and fix em.
RevMeHarder
Jun 1, 2026 02:30 PM
DylanForbes
25
Oct 31, 2017 05:47 PM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
Vedivan1
Sep 18, 2015 12:39 PM
Irvinb16
Sep 11, 2015 10:27 PM
