Searched but can't find specific
Old Jun 17, 2004 | 05:22 PM
VelociRedBeast's Avatar
I keep finding the info but can't specifically find how to check my current flash? You step on the break 20 times? While the car is on or off? The needle will swim..does the needle swim ONLY for the M flash and if not how can I tell teh differance? Please, someone help..
Old Jun 17, 2004 | 05:41 PM
epitrochoid's Avatar
Riot Controller
click IGN to ON
TAP the brake 20+ times
If you are L or greater, the ECU will clear it's fuel trim settings and the oil needle will sweep.
to distinguish between L and M, you'll need to look for a decal
Old Jun 17, 2004 | 06:17 PM
robertdot's Avatar
You have to tap in rapid succession. I tapped it very quickly until I saw the needle sweep (but my foot probably tapped a couple more times). Just tap quickly in rapid succession until it sweeps.
Old Jun 17, 2004 | 06:57 PM
w2aew's Avatar
www.dorkage.com
...what they said, above.
If the needle sweeps you have L or M. If there is no sticker, there is no way for you to determine it. It'll have to go on the computer at the dealer and they would tell you.
Old Jun 17, 2004 | 10:47 PM
That's what I was looking for, thanx epitrochoid, and others..
WranglerFan
Nov 5, 2017 09:35 AM
Trinads
Sep 10, 2015 01:05 PM
tgaffner
Sep 7, 2015 08:49 PM
