Sleeper STI on Tuner Transformation
Old Jun 8, 2004 | 07:01 PM
j1mb0x99's Avatar
Caution!
I just finished watching Tuner Transformations on SPEED channel. The show just redeemed itself after their abomination of the RX-8.
On it they took a Subaru STI and did to it exactly what I would like to do if I owned one.
Retuned the ECU.
New Intercooler.
Added intake.
Added Exhaust.
Installed a rear swaybar.
Upgraded brakes.
Then they painted the stock rims black and swapped a base model hood and trunk lid with the regular STI's.
Total sleeper car.
Just thought I would share and if this is a repost I appologize.
-JiM
Old Jun 8, 2004 | 11:11 PM
Ike's Avatar
Ike
Blue By You
Re: Sleeper STI on Tuner Transformation
Retuned the ECU.
New Intercooler.
Added intake.
Added Exhaust.
Upgraded brakes.
Total sleeper car.
-JiM
Upgraded brakes??? It comes with Brembos, I'm guessing you mean stuff like SS lines, motul fluid etc.
I can't believe they painted thise beautiful BBS wheels, I hope they got it professionally done and it was a black car.
There are a couple black FMICs available for the WRX/STi as well, and it looks really mean. Did they use the black?
Old Jun 9, 2004 | 12:26 AM
wrx2rx8's Avatar
When is this show on? I missed both the rx8 and sti episodes.Saw the weak auto m3 episode.
I dont know if mine was an Sti i think id leave as so. Sleeper would be 02 03 wrx no sti available over here in that body style.
With the car being out longer /more parts it is fairly easy to make faster than the Sti.
The sleeper i want is a miata with 5.0 swap:D
Old Jun 9, 2004 | 09:32 AM
DragonStar4681's Avatar
unfortunatly the car was silver. it didnt look that bad when it was done though.
Old Jun 9, 2004 | 10:39 AM
liqiud's Avatar
i thought it looked good...unfortunately i missed the rx-8 episode, but i try to watch it as much as possible.
Old Jun 9, 2004 | 10:38 PM
Kel Rx8's Avatar
if your not 1st your last
havent seen it
this weeks show ?
aint nothing sleeper about a subaru sti
Old Jun 10, 2004 | 09:16 AM
RX8-TX's Avatar
Senior Geek
[i]aint nothing sleeper about a subaru sti [/B]
Except that it no longer looked like one.
Old Jun 10, 2004 | 10:29 AM
Farsyde's Avatar
I think they took the cahones out of the car. Why spend 30k on a car your buying for only one reason, then strip it down to look like a 7k cheaper car. I'll admit the upgrades were nice, but still. They kept the old calipers and put in SS lines and cross-drilled discs. However, I think that they are gonna run into problems with the new exhaust. The STI boards are flooded with posts about boost-creep issues with any more freely-flowing exhaust is pu on. Since I didn't see any external wastegate or porting the original internal one and not to mention they uped the boost and retuned the computer, I think there may be some future damage to the engine there. All in all though still fun to watch.
Old Jun 10, 2004 | 08:34 PM
wrx2rx8's Avatar
You retune the comp.Cause of the upped boost, to avoid engine problems.Anytime you mod a car/or drive it hard its gonna have future problems you just tune it right . Put that future as far out there as you can.
Old Jun 11, 2004 | 10:01 AM
Farsyde's Avatar
Normally correct, but in the STI's case, wrong. The internal wastegate flange is too small to flow more than the stock boost. For some reason putting a free flowing exhaust on the thing, even without upping the boost, tend to boost-creep. There is NO tuning that can solve this problem as it is a mechanical issue that can only be resolved by porting the wastgate or replacing the system completely with a new turbo and external wastegate.
yurcivicsux
192
Sep 12, 2017 10:54 PM
RX-8 Racing
20
May 14, 2016 06:25 PM
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
Silverhks
Sep 16, 2015 11:55 AM
