Do you disconnect the Negative cable
Old Jun 7, 2004 | 09:43 PM
leegina's Avatar
during install or not? I read in one of the previous posts that RX8 Friend said that he has not disconnceted the ground wire while installing some units without causing any problems or CEL's. That is what I am looking for NO CEL's. So would you recommend disconnecting the negative battery cable or not? Thanks
Old Jun 7, 2004 | 10:48 PM
SMigneco's Avatar
You only need to disconnect the one cable illustrated in Canzoomers instructions.
Old Jun 7, 2004 | 10:51 PM
leegina's Avatar
I seen the instructions on the sticky but what I am referring to is RX8 Friend made a comment (Dont shoot me if I am wrong) that he has not disconnected the negative or any battery cable while installing the unit and has not received any CEL's or mishaps. Anyone know anything about this? Thanks
Old Jun 8, 2004 | 11:30 AM
Xavier296's Avatar
Always tinkering
I have installed and uninstalled multiple times and never got a CEL. Just unhook the battery lead closest to the front of the car and you will not get a CEL. Another trick I figured out is that you don't have to undo the wire clip on the top cover nearest the bumper, just unhook the two wire clips to the sensors and the cover will tilt out of the way easily. Hope that it came today lee!
Old Jun 8, 2004 | 11:41 AM
smrx8's Avatar
dont dissconnect anything i done it couple of times with no problems.
Old Jun 8, 2004 | 03:48 PM
leegina's Avatar
Xavier296 Yes got it. Now you say disconnecting the battery and got no cel's? Thanks
cliffkemp
Dec 24, 2024 10:48 AM
jgsnake
General Automotive
Jul 30, 2023 10:26 AM
Jelliott5384
Oct 26, 2016 05:15 PM
Danield97
Oct 10, 2015 05:58 PM
Evan Gray
Sep 26, 2015 12:30 PM
